I’ve periodically had issues with the unit becoming unresponsive over the network (presumably due to a poor signal) and generally it doesn’t reconnect, necessitating a power cycle to get it going again.
I bought the replacement board with a wired connector a while back and have been using it (without
a physical connection) as it seemed ‘better’ or more reliable than the wireless only board.
However I’ve need to use shaper to limit the charge since I had an ASHP installed and when the Wi-Fi goes, the charging now stops. After my wife’s car failed twice to charge overnight last week, I finally installed a CAT6A STP cable to solve the issue.
However, the unit still connects to Wi-Fi despite also connecting over the wire and when the Wi-Fi drops, the unit is unresponsive on both IP addresses until the Wi-Fi decides to work again.
Also, the System tab is showing a wired connection but the IP is that of the wireless interface.
Is there a way of completely disabling the wireless from starting up?
