Hi, sure thing:
{"firmware":"7.1.3.EU","protocol":"-","espflash":4194304,"espinfo":"ESP32r1 2 core WiFi BLE BT","buildenv":"openevse_wifi_v1","version":"4.1.2","evse_serial":"","wifi_serial":"AC67B206FEB0","mqtt_supported_protocols":["mqtt","mqtts"],"http_supported_protocols":["http"],"diode_check":true,"gfci_check":true,"ground_check":true,"relay_check":true,"vent_check":true,"temp_check":true,"service":0,"scale":220,"offset":0,"max_current_soft":32,"min_current_hard":6,"max_current_hard":32,"ssid":"AlexEVSE","pass":"_DUMMY_PASSWORD","www_username":"","www_password":"","hostname":"OpenEVSE","sntp_hostname":"pool.ntp.org","time_zone":"Europe/London|GMT0BST,M3.5.0/1,M10.5.0","emoncms_server":"http://10.11.12.6","emoncms_node":"openevse","emoncms_apikey":"_DUMMY_PASSWORD","emoncms_fingerprint":"","mqtt_server":"10.11.12.6","mqtt_port":1883,"mqtt_topic":"emon/openevse","mqtt_user":"emonpi","mqtt_pass":"_DUMMY_PASSWORD","mqtt_solar":"","mqtt_grid_ie":"emon/emonpi/importexport","mqtt_vrms":"emon/emonpi/vrms","mqtt_vehicle_soc":"","mqtt_vehicle_range":"","mqtt_vehicle_eta":"","mqtt_announce_topic":"openevse/announce/feb0","ocpp_server":"","ocpp_chargeBoxId":"","ocpp_idTag":"","tx_start_point":"tx_pending","ohm":"","divert_PV_ratio":1.1,"divert_attack_smoothing_factor":0.4,"divert_decay_smoothing_factor":0.1,"divert_min_charge_time":600,"tesla_access_token":"","tesla_refresh_token":"","tesla_created_at":0,"tesla_expires_in":0,"tesla_vehicle_id":"","led_brightness":129,"flags":523,"emoncms_enabled":true,"mqtt_enabled":true,"mqtt_reject_unauthorized":true,"ohm_enabled":false,"sntp_enabled":true,"tesla_enabled":false,"divert_enabled":true,"pause_uses_disabled":false,"mqtt_vehicle_range_miles":false,"ocpp_enabled":false,"ocpp_suspend_evse":false,"ocpp_energize_plug":false,"mqtt_protocol":"mqtt","charge_mode":"fast"}
