OpenEVSE stops posting to EmonCMS
I’m experiencing an intermittent issue where data stops posting from OpenEVSE to EmonCMS. The OpenEVSE is still accessible and controllable. A restart of the Wi-Fi module fixes it. Signal strength is -59 dBm with an AP in the garage as well.
Any ideas?
are you using V4 software as I get this with V4 but not V3
John
Yes, running version 4.0.1
What emoncms server are you posting to? I can’t replicate any posting issues, I’m currently running V4.0.1 since mid-April posting to emoncms.org via HTTPS, my RSSI is -70.
Are you also using MQTT, does MQTT hold the connection successfully?
Take a look at System > Debug on the openevse interface, a successful emoncms connection should periodically return {"emoncms_connected":1,"emoncms_message":"ok"}
I’m running an EmonPi connected by ethernet.
MQTT stays connected.
I’ll check the logs the next time it happens.
Something isn’t working correctly. OpenEVSE should it is connected correctly to EmonCMS:
EmonCMS isn’t showing any data within the Feeds:
But the Input is working!:
I’m not sure what is wrong :frowning:
It looks like it’s posting correctly, the Inputs just need to be mapped to Feeds. This can be automated using the device module, see OpenEVSE Emoncms setup guide: https://guide.openenergymonitor.org/integrations/evse-setup/#emoncms-setup
The feeds are there and have data in them, but I have reinitialised the Inputs to Feeds and data is being captured.
Thanks!
