Im having trouble with my new openevse not holding the max current value and occasionally reverting to 32a. Im running the latest 3.3.2 wifi firmware.
Ive downloaded the firmware to compile with hardcoded max current but am struggling to find my way around the code and unsure on board type etc. Is there any info out there how To do this?
If you want to set a hard limit for max current that can never be exceeded e.g 20A you should use this RAPI command to set a hard limit for your unit. This command can only be issues once and cannot be undone:
$SC 20 M
For explanation of this command see the RAPI documentation:
You can send a rapi command via the web interface once advanced developer mode is enabled. You should receive an OK response.
