I have run into an edge case of sort, I dont know why it happens yet, but sometimes the openEVSE loses the MQTT connection, The web UI still works but the MQTT connection disconnects.
This ran into an issue when using the current shaper, and with a stale grid feed, It stops.
A restart of the wifi module solves this.
More information UI to have more information when the advanced toggle has been selected showing how recent the last mqtt message was would be nice, a bit like the PV divert extra info.
Another quick question, Is it possible to trigger a restart of the wifi board via http?
So I could have a watchdog running external and if it detects that the mqtt isnt updating, It can force a restart?
This happened on 4.1.5. I have now updated to 4.1.7
Thanks for that recommendation… Been looking for something to bounce on wifi in another location.
It’s currently running on an old D-Link repurposed router as an access point. But it is on the same SSID as a main one but due to stone walls and distance it shouldn’t be able to be picked up…
I’ve thankfully long unlinked the wifi from my isp.
This error takes so long to show up it’s hard to pinpoint why. But seems to be mqtt only not the normal http access
