Method in brief: daily totals from the Powerwall gateway and the Octopus smart meter, with daily temperature and sunshine duration from Open-Meteo. Whole-house consumption against mean outdoor temperature, excluding a 27-day holiday, fits a hinge model with a 12.5 °C balance point, 4.3 kWh per degree-day below it and R² = 0.80. Solar against sunshine hours gives r = 0.89, but the slope changes from about 1.3 kWh per sunshine hour in winter to about 3.1 in summer.
Limits I would like views on: I have no separate heat pump input or output meter data in the dataset (the heat pump itself reports an annual SPF of 3.72, about 3.5 COP for hot water in summer and as low as about 3.3 combined in peak winter, and I will do a separate deep dive once I can export the detail), and the Powerwall blurs import and export: it charges from the grid and, from 5 April to 17 September, was set to cycle fully once a day, exporting everything between 11 pm and midnight with a 20% reserve kept, then refilling overnight from the grid, so summer import has a floor of about 15 kWh a day (from June). If you have a similar dataset, I would like to compare the temperature slope and the winter and summer kWh per sunshine hour. Analysis and charts produced with Claude Sonnet 5.5.
Already on it @TrystanLea . The datasets are giving some very nice insights beyond what was covered in your Energy & Buildings paper. I might even think about publishing the analysis!
Interesting dataset. A few technical thoughts on the solar side, since your limits section mentions the changing kWh per sunshine hour slope.
1. The slope change from about 1.3 kWh per sunshine hour in winter to 3.1 in summer is expected, and it is mostly not a sign of anything wrong. “Sunshine duration” is a threshold measure (direct irradiance above roughly 120 W/m2), so it counts a weak low-sun hour in December the same as a strong midday hour in June. In winter at 53N the sun is low, so the irradiance per sunshine hour is much lower, and on a typical UK tilt the plane-of-array gain is partially offset by a longer path through the atmosphere. In summer the sunshine hours are also at higher irradiance. If you can get daily global horizontal irradiation (kWh/m2/day, Open-Meteo provides shortwave radiation) the fit should be much tighter and the seasonal kink should largely disappear. Also try plane-of-array transposition for your actual tilt and azimuth.
2. Diffuse light matters. On overcast days you still get 15 to 30 percent of clear-sky output, which a sunshine-hours metric reads as zero. That will cap your r at around 0.9 and puts a positive intercept in the regression.
3. Check for inverter clipping and export limits in summer. If the array DC size is larger than the inverter AC rating (or you have a G98/G99 export cap), the midday peak flattens and your summer slope is understated.
4. Temperature and soiling. Crystalline silicon loses about 0.3 to 0.4 percent per degree C above 25 C cell temperature, so a hot clear day gives a little less than a cool clear day at the same irradiance. Shading from nearby buildings or chimneys is usually a winter effect because of the low sun elevation, and it can be the reason the winter slope is so low.
5. On the Powerwall: daily full cycling and then refilling from the grid overnight mostly shifts energy rather than saving it. The round-trip efficiency is about 90 percent for the battery (less once you count inverter and standby losses), so each kWh cycled loses roughly 10 percent. If you want a clean number for the true solar self-consumption, estimate it from the gateway’s solar-to-home and solar-to-battery counters rather than from the meter totals, otherwise grid charging contaminates the comparison.
It would also help to know the array size in kWp, tilt and azimuth, so others can normalise to kWh per kWp for comparison.
Thanks, this is really useful. The array is 10.8 kWp, 35 Deg tilt and azimuth split between 6.3 kWp SE and 4.5 kWp NW, so kWh per kWp is just the daily figures divided by 10.8.
On 1 and 2, agreed. Sunshine hours is a blunt threshold measure and I only used it because it was the easy variable to hand. Open-Meteo’s shortwave radiation is the obvious next step, and I’ll try that, plus a plane-of-array transposition, to see whether the winter/summer kink collapses and the intercept behaves. Winter shading on the low sun is a fair suspect for the low winter slope too.
On clipping and export limits, I haven’t checked this properly yet and will look at the midday peaks in summer.
On the Powerwall, agreed that grid charging mostly shifts energy rather than saving it; in the follow-up post I model it at 95% each way, so roughly 90% round trip, and the saving comes from the price gap between windows rather than from the cycling itself. For a clean self-consumption number, using the gateway’s solar-to-home and solar-to-battery counters rather than the meter totals is a good point and I’ll do it that way.
