I have been using emonTx V3 since 2014 and Pi model B as a relay to the Emoncms that I have been running on one com web hotel. I upgraded to Emoncms version 10.2.0 (not the emoncms_org version since it requires redis) for a few months ago, and it worked fine.
Daily I only use the emoncms app on android, so i haven’t been at the site for since upgrade, until today. When I am now trying to log into the Emoncms hostet at one com it looks like this:
I have not done any changes since it was working.
Could this be upgrade of MariaDB (10.3.23) or PHP (7.4) on the one.com that is break the emoncms webpage?
Any ideas to what i can check why the page is broken?
Sorry, I didn’t know it was a log when running on as shared host. But i was able to configure it.
This is what the log is saying when I go from the login to the /feed/list:
2020-10-05 20:55:43.590|ERROR|index.php|Not Authenticated|feed/list
2020-10-05 20:55:43.672|WARN|index.php|406 Not Acceptable|emon/Lib/bootstrap
2020-10-05 20:55:43.675|WARN|index.php|406 Not Acceptable|emon/Lib/bootstrap
2020-10-05 20:55:43.721|WARN|index.php|406 Not Acceptable|emon/Theme/basiccms-base
2020-10-05 20:55:43.724|WARN|index.php|406 Not Acceptable|emon/Lib/misc
2020-10-05 20:55:43.727|WARN|index.php|406 Not Acceptable|emon/Theme/basic-blue
2020-10-05 20:55:43.729|WARN|index.php|406 Not Acceptable|emon/Lib/misc
2020-10-05 20:55:43.777|WARN|index.php|406 Not Acceptable|emon/Libcms
2020-10-05 20:55:43.780|WARN|index.php|406 Not Acceptable|emon/Modules/user
2020-10-05 20:55:44.726|WARN|index.php|406 Not Acceptable|emon/Lib/jquery-1
2020-10-05 20:55:44.729|WARN|index.php|406 Not Acceptable|emon/Lib/misc
2020-10-05 20:55:44.783|WARN|index.php|406 Not Acceptable|emon/Lib/bootstrap
2020-10-05 20:55:44.785|WARN|index.php|406 Not Acceptable|emon/Lib/misc
2020-10-05 20:55:44.787|WARN|index.php|406 Not Acceptable|emon/Theme/basic
2020-10-05 20:55:44.843|WARN|index.php|406 Not Acceptable|emon/Libcms
2020-10-05 20:55:44.905|WARN|index.php|406 Not Acceptable|emon/Modules/user
2020-10-05 20:55:44.967|WARN|index.php|406 Not Acceptable|emon/Lib/bootstrap
2020-10-05 20:55:45.032|WARN|index.php|406 Not Acceptable|emon/Theme/basic
I was not able to get the log apache logs, but i remembered that when I was entering the web page before it was by using mydomain.com/emoncms.
For some reason if I use mydomain.com/emoncms link the web page is working, but if i use emoncms.mydomain.com it does not work and I am getting the strange layout that is shown in the first post.
So my solution for now is to use mydomain.com/emoncms.
That is a host config issue I’d suggest. I’m not aware of any changes to the code base that would cause that to start. I suggest you contact the hosting company support.
