Hi guys,
Any idea how/why a feed generated using ‘Power to kWh’ would go backwards from the latest value?
Did power_consumption go negative?
No.
Also, the latest value in the input configuration doesn’t match the feed latest value (as per screenshots above).
Think this might be self inflicted :man_facepalming: looks like I’ve imported some future data (fixed at 301.4) which would explain the strangeness. Will try nulling out.
