Hi Brian,
I have HA and the node red add on installed and working. Next daft question?
There do i runn your install command from? If i run from a ssh shell i get
npm WARN npm npm does not support Node.js v10.15.2
npm WARN npm You should probably upgrade to a newer version of node as we
npm WARN npm can’t make any promises that npm will work with this version.
npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
npm WARN npm You can find the latest version at https://nodejs.org/
npm WARN saveError ENOENT: no such file or directory, open ‘/home/james/package.json’
npm WARN enoent ENOENT: no such file or directory, open ‘/home/james/package.json’
npm WARN james No description
npm WARN james No repository field.
npm WARN james No README data
npm WARN james No license field.
So it evidently doesnt know where to put everything, and its not apearing as a node.
“I can add this command within the config from HA.” Sorry for being daft, I have no experience of HA or Node red, I can i run this from the GUI somewhere?
Best Regards
James
