Hello all,
Curently, i am using emonpi with SSD to have emoncms integrated with node-red.
I was well advised by @borpin ( Thanks! ) to not use everything on the same machine, the reason i am looking for an alternative.
The problem is that i have a intel machine with gpio but my knowledge is still limited regarding using the gpio on node-red by sysfs, curently replaced by libgpiod. I know that exists node-red-node-pi-gpiod for rpi, mantained by node-red dev Dceejay but not for X86 intel machines (that i am aware of). Can someone knows a alternative (or an example) to do the same on my machine? I am no developer and know very little of coding but don’t have any problem to try build a node if someone point me in the right direction.
My machine is this one: https://www.seeedstudio.com/ODYSSEY-X86J4105800-p-4445.html
Thanks in advance.
Celso
