Hi all,
need a bit of help with my Node red install…
- I started with a fresh build of the latest Emonpi SD image and configured some feeds that are all working well.
- I installed Node red using the script…
“bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered)”
which seems to be the recommended way to do it. - The script seemed to run fine, no errors. I pointed my browser at http://mypi:1880 and got the flow screen. All seemed well.
- I ran the command " sudo systemctl enable nodered.service" to run as a service upon reboot.
- I reboot and goto http://mypi:1880, nothing
- I look for Node red processes, nothing.
- I try to run the install script again ad it errors out with…
Stop Node-RED
Remove old version of Node-RED
node: relocation error: node: symbol ▒sF version GLIBC_2.4 not defined in file libc.so.6 with link time reference
Remove old version of Node.js -
Leave existing Node.js ✘ Failed to install Node.js - Exit
Npm rebuild existing nodes
Add shortcut commands
Update systemd script
Any help would be much appreciated.
TIA
Garry
