wanted to avoid to paste all these lines as it is on this page : victron_thethingbox/node-red_paste at master · liaan/victron_thethingbox · GitHub
but here you go for the export. I was able between the flow of error to see some debug tabs with indeed results from my victron. So it is getting data … it is just that the url build thing is messy. What I do understand is that it cycles around 10 seconds and after that it really posts to the server instead posting every second as it can on a local branch (i deleted those tabs)
"id": "3e72b989.c18d46",
"type": "serial in",
"z": "c4a05491.3b5fa8",
"name": "Mk2",
"serial": "37f5231a.c80adc",
"x": 56,
"y": 743.7142601013184,
"wires": [
"1354798f.ecab86",
"d2f7fbd5.2d0808"
"id": "1354798f.ecab86",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 222.28570938110352,
"y": 794.2856817245483,
"wires": []
"id": "e6aec800.195138",
"type": "inject",
"name": "Get Led Status",
"topic": "",
"payload": "L",
"payloadType": "string",
"repeat": "",
"crontab": "",
"once": false,
"x": 145.7142448425293,
"y": 172,
"wires": [
"f1166d35.0ee99"
"id": "1bcf635a.e4309d",
"type": "template",
"name": "Make Packet",
"field": "payload",
"fieldType": "msg",
"syntax": "mustache",
"template": "{{#leds}}\n\n{{name}} is {{status}}\n\n{{/leds}}",
"x": 1007.5715522766113,
"y": 574.2856750488281,
"wires": [
"79ed8398.86127c"
"id": "d2f7fbd5.2d0808",
"type": "function",
"name": "Decode MK2 String",
"func": "\ncommand = String.fromCharCode(msg.payload[2]);\n\nchecksum = 0;\n\nfor (i=0;i<msg.payload.length;i++){\n checksum = (checksum + msg.payload.readInt8(i))%0x100 ;\n}\nmsg.checksum = checksum\nif(checksum != 0){\n\treturn null\n}\n\nif(msg.payload[1] == 255){ \n\tswitch (command){\n\t\tcase \"L\": //LED Status\n\t\t\t\n\t\t\tmsg.type = 1;\t\t\n\t\t\tmsg.value = [msg.payload[3],msg.payload[4]];\n\t\t\t\n\t\tbreak;\n\t\tcase 'V': // Version\n\t\t \n\t\t msg.type = 2;\n\t\t \n\t\t \n\t\tbreak;\n\t\tcase 'F':\t\t\n\t\t\tmsg.type = 3;\n\t\t\t\n\t\tbreak;\n\t\tdefault:\n\t\t\tmsg.type=0;\n\t\tbreak;\n\t}\n\treturn [msg,null,msg]\n}\n\n//Info Frame\nif(msg.payload[1] == 0x20){\n\t\n\treturn [null,msg,msg];\t\n}\n\n\n",
"outputs": "3",
"x": 257.00000381469727,
"y": 743.9999794960022,
"wires": [
"2fd3c918.d02c36"
"25ffb974.da0046"
"d86b0698.2794f8"
"id": "3e6baed2.c19452",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 661.6507759094238,
"y": 613.0635375976562,
"wires": []
"id": "2fd3c918.d02c36",
"type": "switch",
"name": "Switch MK2 packet type",
"property": "type",
"rules": [
"t": "eq",
"v": "1"
"t": "eq",
"v": "0"
"checkall": "true",
"outputs": 2,
"x": 473.5873603820801,
"y": 649.15869140625,
"wires": [
"3e6baed2.c19452",
"ae5b514a.51a4b"
"8220443.f7ddfb8"
"id": "79ed8398.86127c",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "false",
"x": 1181.1428413391113,
"y": 577.7142944335938,
"wires": []
"id": "ae5b514a.51a4b",
"type": "function",
"name": "Mk2: Decode LED String",
"func": "var leds = Array();\n\nleds[0] = {\n\tname : 'Mains',\n\tstatus : 0\n}\nleds[1] = {\n\tname : 'Absorpion',\n\tstatus : 0\n}\nleds[2] ={\n\tname : 'Bulk',\n\tstatus : 0\n}\nleds[3] = {\n\tname : 'Float',\n\tstatus : ''\n}\nleds[4] = {\n\tname : 'Inverter',\n\tstatus : ''\n}\nleds[5] = {\n\tname : 'Overload',\n\tstatus : ''\n}\nleds[6] = {\n\tname : 'Low Battery',\n\tstatus : ''\n}\nleds[7] = {\n\tname : 'Temperature',\n\tstatus : ''\n}\n\ndecode_on_off (msg.value[0])\ndecode_blinking(msg.value[1])\n\n//Assign LED array\nmsg.leds = leds;\n\n\n//Return\nreturn msg;\n\n\n/*\n* Decode LED on Off\n* \n*/\nfunction decode_on_off(value){\n\n\tfor(i=0;i<8;i++){\n\t\tleds[i]['status'] = (value & 1<<i)?'On':'Off';\n\t\tleds[i]['status_id'] = (value & 1<<i)?1:0;\n\t}\t\t\t\n\n\t\n}\n\n/*\n* Decode Blinking State\n*/\nfunction decode_blinking(value){\n\n\tfor(i=0;i<8;i++){\n\t\n\t\t (value & 1<<i) ? (leds[i]['status'] = 'Blinking'):'';\n\t\t (value & 1<<i) ? (leds[i]['status_id'] = 2):'';\t\t\n\t}\t\t\t\n\n}\n",
"outputs": 1,
"x": 736.3333930969238,
"y": 659.8729858398438,
"wires": [
"1bcf635a.e4309d",
"6c74e91.f938b18"
"id": "2a68d702.d59728",
"type": "inject",
"name": "Get AC/DC/LED Info State",
"topic": "0",
"payload": "F",
"payloadType": "none",
"repeat": "0.2",
"crontab": "",
"once": false,
"x": 176.80946731567383,
"y": 425.25396728515625,
"wires": [
"739dcc7e.8c6234"
"id": "da892a11.2576d8",
"type": "inject",
"name": "Get MasterLED State",
"topic": "5",
"payload": "F",
"repeat": "",
"crontab": "",
"once": false,
"x": 157.80949783325195,
"y": 217.53968811035156,
"wires": [
"f1166d35.0ee99"
"id": "8220443.f7ddfb8",
"type": "debug",
"name": "Unkown Frame",
"active": false,
"console": "false",
"complete": "true",
"x": 593.5714302062988,
"y": 721.1428833007812,
"wires": []
"id": "ea75361f.158ac8",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 916.5714302062988,
"y": 752.1428833007812,
"wires": []
"id": "6c74e91.f938b18",
"type": "function",
"name": "LED to emoncms",
"func": "var bla = {};\nvar newMsg = {};\nnewMsg.values = make_emoncms(msg.leds)\n\n//bla.nodegroup = \"ab\";\n//msg = bla;\nnewMsg.node = 0;\nnewMsg.packet_type = 3;\n\nreturn newMsg;\n\nfunction make_emoncms(leds){\n\t//var payload = \"1\";\n\tvar payload = {};\n\t//payload2 = {};\n\t\n\tleds.forEach(function (byte,index) {\n\t\t\n\t\tvar color = 10;\n\t\tswitch (byte.status_id)\n\t\t{\n\t\t\tcase 0: //off\n\t\t\t color = 10 //green\n\t\t\t break;\n\t\t\tcase 1://on\n\t\t\t color=1\n\t\t\t break;\n\t\t\tcase 2://blink\n\t\t\t color = 4\n\t\t\t break\n\t\t\tdefault:\n\t\t\t color = 5\n\t\t\t break;\n\t\t}\n // payload += ','+[byte.name]+':'+color\n\t payload[byte.name] = color\n\t \n\t})\n\treturn payload;\n\t//return JSON.stringify(payload);\n}",
"outputs": 1,
"x": 789.5714302062988,
"y": 814.1428833007812,
"wires": [
"ea75361f.158ac8",
"d46a9f17.2b956"
"id": "25ffb974.da0046",
"type": "function",
"name": "Decode Info Frame",
"func": "try{\nvar packet = Array();\nvar phase = msg.payload[2+4];\n\nswitch (phase){\n\tcase 0x0C: //DC\n\t\t//msg.values = decode_dc();\n\t\tmsg.type = 1;\n\t\tmsg.run = 'DC';\n\tbreak;\n\tcase 0x08: //AC L1\n\t\t//msg.values = decode_ac();\n\t\tmsg.run = 'ac';\n\t\tmsg.type = 2;\n\tbreak;\n\tdefault:\n\t\tmsg.run = 'Unkown packet'+ phase.charCodeAt(0);\n\tbreak;\n}\n\nreturn msg;\n\n\n}catch(e){\n\tconsole.log(e);\n\treturn msg;\n}",
"outputs": 1,
"x": 400.2856864929199,
"y": 963.0000324249268,
"wires": [
"b6e29220.491d7",
"a47e5d1e.5b81a"
"id": "b6e29220.491d7",
"type": "switch",
"name": "",
"property": "type",
"rules": [
"t": "eq",
"v": "1"
"t": "eq",
"v": "2"
"checkall": "true",
"outputs": 2,
"x": 581.1428337097168,
"y": 961.5714340209961,
"wires": [
"afe5f9d5.501a08"
"4671b523.b98e4c"
"id": "4671b523.b98e4c",
"type": "function",
"name": "Decode AC Frame",
"func": "try { \n\nmsg.values = decode_ac(msg.payload);\nmsg.type = 'Inverter AC'\nmsg.node = 1;\nmsg.packet_type = 2;\nreturn msg;\nfunction decode_ac(packet){\n\tvar ac = {\t\n\t\tbf_factor: packet.readInt8(2+0)\n\t ,inverter_factor: packet.readUInt8(2+1)\n\t ,mains_volt: packet.readInt16LE(2+5)/100\n\t\t,mains_current : packet.readInt16LE(2+7)/100 //((packet[2+7])+(packet[2+8]*255))/100\n\t\t,inverter_voltage : packet.readInt16LE(2+9)/100 //((packet[2+9])+(packet[2+10]*255))/100\n\t\t,inverter_current : packet.readInt16LE(2+11)/100 // ((packet[2+11])+(packet[2+12]*255))/100\n\t\t,mains_period : 10/(packet.readUInt8(2+13)*0.0010235414534288639)\n\t\t\n\t}\n\t\n\tac['mains_watts'] = (ac.mains_current * ac.mains_volt * ac.bf_factor);\n\tac['inverter_watts'] = (ac.inverter_voltage * ac.inverter_current * ac.inverter_factor);\n\tac['InverterWattsOut'] = ac['inverter_watts'] \n\t\n\treturn ac;\n}\n}catch(e){\nconsole.log(e)\n}",
"outputs": 1,
"x": 789.1428413391113,
"y": 1072.5714111328125,
"wires": [
"d46a9f17.2b956",
"f0221e51.0fdde"
"id": "afe5f9d5.501a08",
"type": "function",
"name": "Decode DC Frame",
"func": "try {\n\n\n\nmsg.values = decode_dc(msg.payload)\nmsg.type = 'Inverter DC'\nmsg.node = 1;\nmsg.packet_type = 1;\nreturn msg;\n\nfunction decode_dc(packet){\n\tvar dc = {\n\t\t\n\t\tbat_volt: packet.readInt16LE(2+5)/100 //cket[2+5])+packet[2+6]*255)/100\n\t\t,bat_current_used : ((packet[2+7])+(packet[2+8]*255)+(packet[2+9]*255*255))/10\n\t\t,bat_current_charge : ((packet[2+10])+(packet[2+11]*255)+(packet[2+12]*255*255))/10\n\t\t,bat_inverter_period : 10/((packet.readUInt8(2+13)+256)*0.0005099)\n\t\t\n\t}\n\t\n\tdc['bat_watts'] = (dc.bat_current_used * dc.bat_volt);\n\tdc['bat_charge_watts'] = (dc.bat_current_charge * dc.bat_volt);\n\t\n\treturn dc;\n}\n\n\n\n}\ncatch(e){\nconsole.log(e)\n}\n",
"outputs": 1,
"x": 787.1428413391113,
"y": 890.5714111328125,
"wires": [
"79aef29c.86510c",
"d46a9f17.2b956"
"id": "a47e5d1e.5b81a",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 560.2856864929199,
"y": 1082.4285488128662,
"wires": []
"id": "ac45aed5.53ba5",
"type": "function",
"name": "Build EmonCMS url",
"func": "// The received message is stored in 'msg'\n// It will have at least a 'payload' property:\n// console.log(msg.payload);\n// The 'context' object is available to store state\n// between invocations of the function\n// context = {};\n\n//expects JSON payload and destination specified in topic\nvar diff = 0;\nif(context.lastrun !== undefined){\n\n\tdiff = (new Date()/1000) - context.lastrun;\n\n\tif(diff < 10)\n\t{\n\t\tbla = \"diff = \" + diff;\n\t\treturn [null,bla]\n\t}\n}\n\ncontext.lastrun = new Date()/1000;\n\nvar key = \"emoncms api key\";\n\n//destination will be last part node of topic\nvar values = JSON.stringify(msg.values);\nvar node = msg.node;\n//console.log(values);\n\nif(isNaN(node))\n{\n//not a valid destination\nreturn null;\n}\n\nmsg.url =\"https://wouters.fr/emon/input/post.json?node=\";\nmsg.url += node;\nmsg.url += \"&json=\";\nmsg.url += values;\nmsg.url += \"&apikey=\";\nmsg.url += key;\n\nif(msg.timestamp !== undefined){\n\tmsg.url += \"&time=\"+msg.timestamp\n}else{\n\tmsg.url += \"&time=\"+Math.floor(Date.now() / 1000)\n}\n//console.log(msg.url);\n\nreturn [msg ,\"posted: \" +diff];",
"outputs": "2",
"noerr": 0,
"x": 1285.8928413391113,
"y": 894.0714721679688,
"wires": [
"aa426571.55bd98",
"9b604af9.649fb8"
"5a59ec21.a5a614"
"id": "aa426571.55bd98",
"type": "http request",
"name": "HTTP GET to EmonCMS.org",
"method": "GET",
"ret": "txt",
"url": "",
"tls": "",
"x": 1536.8095893859863,
"y": 815.8214721679688,
"wires": [
"b20c8df.f4df37"
"id": "b20c8df.f4df37",
"type": "debug",
"name": "EmonCMS HTTP Request Result",
"active": false,
"console": "false",
"complete": "true",
"x": 1846.8095703125,
"y": 821.6548461914062,
"wires": []
"id": "79aef29c.86510c",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 828.1428413391113,
"y": 961.3214721679688,
"wires": []
"id": "1d1b53c6.e2e4ac",
"type": "debug",
"name": "EmonCMS URL",
"active": false,
"console": "false",
"complete": "true",
"x": 1745.3928413391113,
"y": 889.3214721679688,
"wires": []
"id": "9b604af9.649fb8",
"type": "function",
"name": "Debug EmonCMS URL",
"func": "// The received message is stored in 'msg'\n// It will have at least a 'payload' property:\n// console.log(msg.payload);\n// The 'context' object is available to store state\n// between invocations of the function\n// context = {};\n\n\nreturn msg.url;",
"outputs": 1,
"noerr": 0,
"x": 1529.1428413391113,
"y": 898.0714721679688,
"wires": [
"1d1b53c6.e2e4ac"
"id": "2df41437.d20bec",
"type": "serial out",
"name": "Mk2_out",
"x": 1092.8571434020996,
"y": 181.1428508758545,
"wires": []
"id": "2525bb02.dada44",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 1024.698398590088,
"y": 248.74605178833008,
"wires": []
"id": "f1166d35.0ee99",
"type": "function",
"name": "Make Command",
"func": "\ncmd = msg.payload;\ncmd = cmd.charCodeAt(0);\ndata = msg.topic\n\nvar packet = [];\npacket.push(0xff);\npacket.push(cmd);\nif(data !==''){\n\tpacket.push(data);\n}\n\nlength = packet.length;\n//Add Length to begining\npacket.unshift(length)\n//Calculate Checksum\nchecksum = 0;\n\npacket.forEach(function (byte) {\n checksum -= byte;\n}) \n\n//checksum = 0xB3;\n\n\n//Add Checksum to end\npacket.push(checksum);\n\n\n//Make it a Buffer and assign to payload\nmsg.payload = new Buffer(packet,'hex');\n\n\nreturn [msg];",
"outputs": "1",
"x": 821.0000190734863,
"y": 204.42856216430664,
"wires": [
"2525bb02.dada44",
"2df41437.d20bec"
"id": "9460a65b.6b9f58",
"type": "change",
"name": "DC",
"action": "replace",
"property": "topic",
"from": "",
"to": "0",
"reg": false,
"x": 328.3968391418457,
"y": 291.50794982910156,
"wires": [
"61e6f000.9e191"
"id": "61e6f000.9e191",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "150",
"timeoutUnits": "milliseconds",
"rate": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"x": 470.1111030578613,
"y": 290.7936553955078,
"wires": [
"f1166d35.0ee99"
"id": "d72ad86.f28d528",
"type": "change",
"name": "AC",
"from": "",
"to": "1",
"reg": false,
"x": 327.5396614074707,
"y": 249.65081024169922,
"wires": [
"f1166d35.0ee99"
"id": "d86b0698.2794f8",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "checksum",
"x": 448.2856636047363,
"y": 873,
"wires": []
"id": "9e8d829.f61728",
"type": "change",
"name": "LED",
"property": "payload",
"from": "",
"to": "L",
"reg": false,
"x": 326.3967475891113,
"y": 337.22222900390625,
"wires": [
"e561e1cf.1a9e2"
"id": "e561e1cf.1a9e2",
"type": "delay",
"name": "",
"timeout": "350",
"rate": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"x": 469.3967475891113,
"y": 338.22222900390625,
"wires": [
"f1166d35.0ee99"
"id": "d46a9f17.2b956",
"type": "function",
"name": "Merge Packets",
"func": "\n//Set defaults if not set yet\nif(context.dc === undefined){\n\tcontext.dc = false;\n}\nif(context.led === undefined){\n\tcontext.ac = false;\n}\nif(context.packet === undefined){\n\tcontext.packet = {};\n}\nif(context.led === undefined){\n\tcontext.led = false;\n}\n\nif(msg.packet_type === 1){\n\n\tcontext.dc = true;\n}\n\nif (msg.packet_type === 2){\n\tcontext.ac = true;\n}\nif (msg.packet_type === 3){\n\tcontext.led = true;\n}\n\n\nObject.keys(msg.values).forEach(function(key) {\n \t\tcontext.packet[key] = msg.values[key];\n\n});\n\n\n\nif(context.dc && context.ac && context.led){\n\t//var newMsg = { values: context.packet }\n msg.values = context.packet;\n context.ac = false;\n context.dc = false;\n delete context.packet;\n \n\treturn msg;\n}else {\n\treturn [null]\n}\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 1152.2856636047363,
"y": 1016,
"wires": [
"661d2d37.99e2d4",
"ac45aed5.53ba5"
"id": "661d2d37.99e2d4",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 1324.2856636047363,
"y": 1018,
"wires": []
"id": "5a59ec21.a5a614",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 1499.2856636047363,
"y": 984,
"wires": []
"id": "739dcc7e.8c6234",
"type": "function",
"name": "Next Packet",
"func": "delete msg.payload;\nif(context.count == undefined || context.count 3){\n\tcontext.count = 1\n}\nif(context.running == undefined){\n\tcontext.running = false;\n}\n//if already running, return .\nif(context.running === true){\n\treturn [null]\n}\ncontext.running = true;\n// AC\nif(context.count === 1){\n\tmsg.topic = 1;\n\tmsg.payload = \"F\";\n\t\n}\n//DC\nif(context.count === 2){\n\tmsg.topic = 0;\n\tmsg.payload = \"F\";\n\t\n}\nif(context.count === 3){\n\tmsg.topic = '';\n\tmsg.payload = \"L\";\n\t\n}\n\ncontext.count += 1\ncontext.running = false;\nreturn msg;",
"outputs": 1,
"x": 408.50786209106445,
"y": 424.2221984863281,
"wires": [
"c798b240.38675",
"f1166d35.0ee99"
"id": "c798b240.38675",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 570.5078926086426,
"y": 424.1111145019531,
"wires": []
"id": "74f3b87b.8b0c48",
"type": "inject",
"name": "Manual Trigger",
"topic": "",
"payload": "F",
"repeat": "",
"crontab": "",
"once": false,
"x": 147.28566360473633,
"y": 298,
"wires": [
"d72ad86.f28d528",
"9460a65b.6b9f58",
"9e8d829.f61728"
"id": "f0221e51.0fdde",
"type": "debug",
"name": "",
"active": false,
"console": "false",
"complete": "true",
"x": 823.2856636047363,
"y": 1011,
"wires": []
"id": "37f5231a.c80adc",
"type": "serial-port",
"serialport": "/dev/ttyUSB0",
"serialbaud": "2400",
"databits": "8",
"parity": "none",
"stopbits": "1",
"newline": "85",
"bin": "bin",
"out": "time",
"addchar": true
