Hi. I have been working with a GSM module (SIM800L) and a PIR sensor, I want to send the sensed data to the emoncms platform using the POST method, but I have not been able to do it. If anyone has any ideas, I would appreciate it.
Welcome to the OEM Forum, Jose.
Did you look at the documents for the emonCMS API?
They are here:
and specifically, for the Input:
https://emoncms.org/site/api#input
If that does not answer your question, please ask again.
If I’ve been watching that part, I could even publish data with a Wi-Fi module, but now I want to do it with a sim800l gsm.
Your question then is: “How do I program the SIM800L?”
An Internet search shows me that there is a datasheet for the AT command set:
I do not think anyone had used that device here, so it might be that you are the first. You could try asking on the Adafruit forum.
Thank you very much Roberto, I will keep trying and ask in the Adafruit forum.
