I have just created a duplicate emoncms on a new PI3 with a new sd card.
I am using @Paul 's dropbox script so I was able to import my existing set up.
Every thing looks OK but I am not receiving my test mqtt input on the new setup. I immediately went to look at the emoncms.log but nothing shows in admin and the file is zero length. I have done:-
sudo touch /var/log/emoncms.log followed by
sudo chmod 666 /var/log/emoncms.log
I had not followed the mqtt install instrucuions here:-
Progress being made. Log:-
2016-08-05 16:14:46.774|INFO|feed_model.php|EngineClass() Autoloaded new instance of ‘PHPFiwa’.
2016-08-05 16:14:46.822|INFO|feed_model.php|EngineClass() Autoloaded new instance of ‘PHPTimeSeries’.
2016-08-06 11:23:45.672|WARN|phpmqtt_input.php|Starting MQTT Input script
However I am not seeing any connecting info in log, investigating further.
I do not have the mqtt_input service running. Is this the latest way to use mqtt inputs and if so how do you upgrade from phpmqtt_input.php?
Would recommend using latest emonSD-03may16 that has everything ready setup and configured. The pre installed emoncms backup module can be used to restore your data from older system;
OK I am trying the emonSD-03may16 image. I have got it configured and wifi setup. The new setup has the backup module. The original setup I want to copy is 9.7 | 2016.05.25 and has no admin, only administration. No provision such as Admin > emonPi update.
Can I add backup module manually?
My setup is emonbase only without radio receiving data over the internet. I use external node red and external mqtt on their own separate server as they are used for many other applications in addition to emoncms. Up to now I do not use emonhub. That was why initially I tried to setup from scratch as I have done in the past.
