Hello,
I’ve written the 3phase firmware to my new emonTX but I don’t see it as an input on the emonBase (unfortunately I never tried with the stock firmware). My only available inputs are emonpi, emonth5 and emontx3cm15 – they all say n/a NULL but I’m not sure that’s related.
As per the docs I have checked the log file on the emonBase and do NOT see any DEBUG RFM2Pi 8 NEW FRAME : OK lines so I assume that the emonBase is not seeing anything from the TX.
The serial output on the TX is as follows (the CTs are not connected):
OpenEnergyMonitor.org
emonTx V3.4 CT1234 Voltage 3 Phase PLL example - Firmware version 1.40
Using RFM69CW Radio
No EEPROM config
Calibration:
vCal = 268.97
i1Cal = 90.91
i1Lead = 2.00
i2Cal = 90.91
i2Lead = 2.00
i3Cal = 90.91
i3Lead = 2.00
i4Cal = 16.67
i4Lead = 0.20
Network: 210
Node: 11 Freq: 433MHz
POST…wait 10s
‘+++’ then [Enter] for config mode
0.00 0.000 0.000 0.000 0.000 0.00 0.00 0.00 0.00 0.000 0.0000 0.0000 0.0000 0.0000 300.00 Pulses=1 PLL is unlocked
247.29 0.000 0.000 0.000 0.000 0.00 -48.63 -53.46 0.00 49.948 0.0000 0.0000 0.0000 0.0000 300.00 Pulses=1 PLL is locked
247.35 0.000 0.000 0.000 0.000 0.00 0.00 -0.10 0.00 49.986 0.0000 0.0000 0.0000 0.0000 300.00 Pulses=1 PLL is locked
246.64 0.000 0.000 0.000 0.000 0.00 0.19 0.46 0.00 49.979 0.0000 0.0000 0.0000 0.0000 300.00 Pulses=1 PLL is locked
246.31 0.000 0.000 0.000 0.000 0.00 0.01 -0.30 0.00 49.977 0.0000 0.0000 0.0000 0.0000 300.00 Pulses=1 PLL is locked
Does anyone have any ideas? I’ll be the first to admit that I’m a bit out of my depth (!!) but this is my first foray into Arduino/emon stuff and I’ve managed to get this far so I’m hoping it’s something really obvious!
Cheers,
Ben
