OK I confess to committing the cardinal sin - updating 2 things at once ![]()
Previously running without problems:
- 2017 emonpi with emonSD-24Jul20
- emoncms version, probably last updated 6-12months ago? (11.3)
- 2 x emontx3 running CM firmware
- 2 x emonth
After making and downloading a backup, I fitted a just-purchased preloaded industrial SD card, which appeared to install ok, then immediately updated the emonpi firmware to the Feb 2023 CM version (before checking anything, woops), and finally restored from the old SD card. Result: no inputs (but graphs of old data, for example, are there, so the import appears to have worked ok).
So I swapped back to the old SD card. Same result, no inputs.
Firmware update log:
emonPi_CM_LPL Firmware Upload
Downloading firmware from:
https://github.com/openenergymonitor/emonpi/releases/download/20-04-23/emonPi_CM_LPL_1_1_4.hex
Downloaded file:
-rw-r--r-- 1 pi pi 88K Apr 20 2023 /opt/openenergymonitor/data/firmware/emonPi_CM_LPL.hex
EmonHub is running, stopping EmonHub
Uploading emonPi_CM_LPL on serial port ttyAMA0
Attempt 1...
avrdude-original: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyAMA0
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f (probably m328p)
avrdude-original: reading input file "/opt/openenergymonitor/data/firmware/emonPi_CM_LPL.hex"
avrdude-original: writing flash (31868 bytes):
Writing | ################################################## | 100% 4.63s
avrdude-original: 31868 bytes of flash written
avrdude-original: verifying flash memory against /opt/openenergymonitor/data/firmware/emonPi_CM_LPL.hex:
avrdude-original: load data flash data from input file /opt/openenergymonitor/data/firmware/emonPi_CM_LPL.hex:
avrdude-original: input file /opt/openenergymonitor/data/firmware/emonPi_CM_LPL.hex contains 31868 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 3.42s
avrdude-original: verifying ...
avrdude-original: 31868 bytes of flash verified
avrdude-original done. Thank you.
avrdude-original: Using autoreset DTR on GPIO Pin 7
SUCCESS: flash verifed
Restarting EmonHub
Emonhub startup log:
2023-10-24 17:17:04,200 INFO MainThread Exiting hub...
2023-10-24 17:17:04,373 INFO MainThread Exit completed
2023-10-24 17:17:05,827 INFO MainThread EmonHub v2.5.2
2023-10-24 17:17:05,828 INFO MainThread Opening hub...
2023-10-24 17:17:05,828 INFO MainThread Running as user: pi
2023-10-24 17:17:05,829 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2023-10-24 17:17:07,833 WARNING MainThread Device communication error - check settings
2023-10-24 17:17:07,834 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2023-10-24 17:17:08,836 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2023-10-24 17:17:09,838 INFO MainThread Setting RFM2Pi group: 210 (210g)
2023-10-24 17:17:10,841 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2023-10-24 17:17:11,843 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2023-10-24 17:17:12,846 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2023-10-24 17:17:12,851 INFO MainThread Setting MQTT node_format_enable: 1
2023-10-24 17:17:12,852 INFO MainThread Setting MQTT nodevar_format_enable: 1
2023-10-24 17:17:12,852 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2023-10-24 17:17:12,854 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2023-10-24 17:17:12,857 WARNING MainThread Setting emoncmsorg apikey: obscured
2023-10-24 17:17:12,859 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2023-10-24 17:17:12,859 INFO MainThread Setting emoncmsorg senddata: 1
2023-10-24 17:17:12,860 INFO MainThread Setting emoncmsorg sendstatus: 1
2023-10-24 17:17:12,860 INFO MainThread Setting emoncmsorg sendnames: 0
2023-10-24 17:17:12,861 INFO MainThread Setting emoncmsorg compress: 0
Given the warning ‘Device communication error - check settings’, here is emonhub config:
####################### emonhub.conf #########################
### emonHub configuration file, for info see documentation:
### https://github.com/openenergymonitor/emonhub/blob/emon-pi/conf/emonhub.conf
####################### emonHub settings #######################
[hub]
### loglevel must be one of INFO, INFO, WARNING, ERROR, and CRITICAL
loglevel = INFO
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
[[RFM2Pi]]
Type = EmonHubJeeInterfacer
[[[init_settings]]]
com_port = /dev/ttyAMA0
com_baud = 38400 # 9600 for old RFM12Pi
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
subchannels = ToRFM12,
group = 210
frequency = 433
baseid = 5 # emonPi / emonBase nodeID
calibration = 230V # (UK/EU: 230V, US: 110V)
quiet = true # Disable quite mode (default enabled) to enable RF packet debugging, show packets which fail crc
# interval = 0 # Interval to transmit time to emonGLCD (seconds)
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 127.0.0.1
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
# emonhub/rx/10/values format
node_format_enable = 1
nodevar_format_enable = 1
[[emoncmsorg]]
[[[init_settings]]]
url = https://emoncms.org
senddata = 1 # Enable sending data to Emoncms.org
sendstatus = 1 # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
sendinterval= 30 # Bulk send interval to Emoncms.org in seconds
####################### Nodes #######################
[nodes]
## See config user guide: https://github.com/openenergymonitor/emonhub/blob/emon-pi/conf/emonhub.conf
[[5]]
nodename = emonpi
[[[rx]]]
names = power1,power2,power1pluspower2,vrms,t1,t2,t3,t4,t5,t6,pulsecount
datacodes = h, h, h, h, h, h, h, h, h, h, L
scales = 1,1,1,0.01,0.1,0.1,0.1,0.1,0.1,0.1,1
units = W,W,W,V,C,C,C,C,C,C,p
[[6]]
nodename = emontxshield
[[[rx]]]
names = power1, power2, power3, power4, vrms
datacode = h
scales = 1,1,1,1,0.01
units =W,W,W,W,V
[[7]]
nodename = emontx4
[[[rx]]]
names = power1, power2, power3, power4, vrms, temp1, temp2, temp3, temp4, temp5, temp6, pulse
datacodes = h,h,h,h,h,h,h,h,h,h,h,L
scales = 1,1,1,1,0.01,0.1,0.1, 0.1,0.1,0.1,0.1,1
units =W,W,W,W,V,C,C,C,C,C,C,p
[[8]]
nodename = emontx3
[[[rx]]]
[[9]]
nodename = emontx2
[[[rx]]]
datacode = h
[[10]]
nodename = emontx1
[[[rx]]]
datacode = h
[[11]]
nodename = 3phase
[[[rx]]]
names = powerL1, powerL2, powerL3, power4, Vrms, temp1, temp2, temp3, temp4, temp5, temp6, pulse
scales = 1,1,1,1,0.01,0.1,0.1,0.1,0.1,0.1,0.1,1
[[12]]
nodename = 3phase2
[[[rx]]]
[[13]]
nodename = 3phase3
[[[rx]]]
[[14]]
nodename = 3phase4
[[[rx]]]
[[19]]
nodename = emonth1
[[[rx]]]
names = temperature, external temperature, humidity, battery
datacode = h
scales = 0.1,0.1,0.1,0.1
units = C,C,%,V
[[20]]
nodename = emonth2
[[[rx]]]
datacode = h
units = C,C,%,V
[[21]]
nodename = emonth3
[[[rx]]]
datacode = h
units = C,C,%,V
[[22]]
nodename = emonth4
[[[rx]]]
datacode = h
units = C,C,%,V
[[23]]
nodename = emonth5
[[[rx]]]
names = temperature, external temperature, humidity, battery, pulsecount
datacodes = h,h,h,h,L
scales = 0.1,0.1,0.1,0.1,1
units = C,C,%,V,p
[[24]]
nodename = emonth6
[[[rx]]]
units = C,C,%,V,p
[[25]]
nodename = emonth7
[[[rx]]]
units = C,C,%,V,p
[[26]]
nodename = emonth8
[[[rx]]]
units = C,C,%,V,p
[[15]]
nodename = emontx3cm15
[[[rx]]]
names = MSG, Vrms, P1, P2, P3, P4, E1, E2, E3, E4, T1, T2, T3, pulse
datacodes = L,h,h,h,h,h,L,L,L,L,h,h,h,L
scales = 1,0.01,1,1,1,1,1,1,1,1,0.01,0.01,0.01,1
units = n,V,W,W,W,W,Wh,Wh,Wh,Wh,C,C,C,p
whitening = 1
[[16]]
nodename = emontx3cm16
[[[rx]]]
whitening = 1
I guess I’ve done something silly somewhere… any ideas?
