No data or graphs on heatpumpmonitor.org after alterations
Hi
newbie here….
I have a Vaillant Arotherm+ 12kW and the eBUS Adapter Shield C6 on the ebus reporting through MQTT to an emoncms setup on Home Assistant. I have learnt SO MUCH about the ebus in the last few weeks :grin:
It was all working OK (after a few false starts) and it was reporting via emoncms.org to heatpumpmonitor.org.
I realised this I was using the Vaillant “yield” rather than the normal definition of yield, so after correcting the fields I deleted all my data up to the point it was changed to start again fresh.
The emoncms graphs and data disappeared and I had to resync the pointers in HA before the synchronisation started again, but now all is well on both Home Assistant and emoncms.org.
However, it has also disappeared on heatpumpmonitor.org.
I have deleted and recreated the system (twice) but it will still not show the data and graphs again.
Does anyone have any suggestions on how to bring them bacK
TIA
Jan (aka Gilbert the Snotty Alien)
No reply heard and even though the data has been good for a while it still isn’t published so I have deleted the system from heatpumpmonitor
Did you buy your heatpump monitor here?
If you did, remember on-line support is included in the price, so email The Shop and link to this Topic.
Thanks for the reply. I didn’t buy it from the shop, and it is just an ebus adapter linked to emoncms under Home Assistant.
It is now running well, so I’ll let it get to 100% data quality and submit again.
Kind regards
Jan
If you are sending accurate data and have been for a while, and it still doesn’t show up, it’s worth either posting here again with a “mention” to @TrystanLea or try an email.
I have nearly a month’s worth of data and over 95% quality but it still will not show.
I have deleted and reconfigured my system on heatpumpmonitor.org but it will not show.
I have used the “delete all data and reload” and still no change.
@TrystanLea are you able to help with this?
TIA
Jan
