Yes to following those instructions. Jumper changed, Wi-Fi connected fine. Web interface connected ok and if I input data via the http string it shows up but my 2 inputs are not showing and I cannot connected to emoncms
If you connect via miniterm
direct to the TX, do you get the serial output in the console?
I’ll have to take a look later
You do need to switch between output by radio (the default) and wired serial.
Connect a programmer (or equivalent) to the emonTx and at power-up, when invited, send the command “+++”, then send w0
to turn off wireless. This will automatically turn on the serial output in a format I believe suitable for the ESP8266.
Ok, I’ll investigate a ‘programmer’ later. I’ve not had to connect like this before
Thanks for the info
‘programmer’ being anything that you can talk serial in both directions at 115200 baud.
Beware, the serial port on the emonTx is wrongly labelled. The connection marked “Tx” is looking for data incoming from a real Tx, and the connection marked “Rx” is looking for a real Rx that can accept data.
Guess that was a waste of £25 then. I’ve no equipment to do that.
Thanks anyway
£25?
https://shop.openenergymonitor.com/programmers/
£7 + postage. Even next day tracked & signed for won’t cost £18.
No I meant the purchase of the enonESP.
I’ll consider purchasing a programmer.
Thanks for the info
@Gwil, I think there should be something about this on the ESP shop page.
@glyn.hudson could the ESP firmware actually set serial on, on boot?
@Robert.Wall, For older firmware, was Serial enabled by default?
@borpin
Originally, it was radio only. I think serial was added at some point, I know there were some complaints because the radio was left on as well as serial when only serial was wanted. I think the “either - or” happened when whitening was introduced.
What’s missing from the emonTx is sufficient I/O to be able to have a bank of DIP switches to be able to select all the options that it’s accrued over the years.
You will still use your ESP8266 once you have changed the output of the emonTx over. You will need to disconnect the ESP to do it, check that the serial output is present with the correct format, then reconnect the ESP, and you should see your output.
It might be possible to use another serial comms program to talk to the programmer, but the simplest is probably the Arduino IDE, which will be useful if you want to update or change something else. Instructions for setting that up are in the ‘Learn’ section. You won’t need any of the libraries until you come to change the sketch itself and recompile and reload it.
I’ve purchased the programmer via the shop it’s just not something I expected to have to purchase or do as there is no mention of the need to change the EmonTx settings in relation to the EmonESP
Yes, I think a good solution would be for the emonESP firmware to automatically configure the emonTx github issue added. In the meantime until this functions has been implemented and tested we will remove the emonESP from the shop as an individual item and only sell it in conjunction with a correctly configured emonTx.
Yes, the discrete sampling FW had serial in EmonESP format always switched on by default. This issue was introduced when we switched to the continuous sampling firmware.
The programmer arrived today, I believe I’ve connected to it correctly and turned RF to off. Now just testing to see if any data from the feeds appears in the ESP latest data section.
I’ve still had no joy getting a connection to emoncms.org using the web interface, it just always shows ‘Connected’ as No
I presuming the RF setting is persistent after the ESP has been powered off and rebooted?
If you saved the settings, then yes, the emonTx will retain that. Otherwise, it will revert to whatever it was when you next power up.
Available commands for config during start-up:
b - set r.f. band n = a single numeral: 4 = 433MHz, 8 = 868MHz, 9 = 915MHz (may require hardware change)
g - set Network Group nnn - an integer (OEM default = 210)
i - set node ID i= an integer (standard node ids are 1…30)
r - restore sketch defaults
s - save config to EEPROM
v - show firmware version
w - turn RFM Wireless data on or off:
- x = 0 for OFF, x = 1 for ON, x = 2 for ON with whitening
x - exit and continue
? - show this text againAvailable commands only when running:
k <yy.y> <zz.z>
- Calibrate an analogue input channel:
- x = a single numeral: 0 = voltage calibration, 1 = ct1 calibration, 2 = ct2 calibration, etc
- yy.y = a floating point number for the voltage/current calibration constant
- zz.z = a floating point number for the phase calibration for this c.t. (z is not needed, or ignored if supplied, when x = 0)
- e.g. k0 256.8
- k1 90.9 2.00
l - list the config values
m - meter pulse counting:
x = 0 for OFF, x = 1 for ON, = an integer for the pulse minimum period in ms. (y is not needed, or ignored when x = 0)
p<xx.x> - xx.x = a floating point number for the datalogging period
t0 - turn temperature measurement on or off:
- y = 0 for OFF, y = 1 for ON
t
- change a temperature sensor’s address or position:
- x = a single numeral: the position of the sensor in the list (1-based)
- yy = 8 hexadecimal bytes representing the sensor’s address
e.g. 28 81 43 31 07 00 00 D9
N.B. Sensors CANNOT be added.
Great, I was just googling for that answer as it’s clear that the setting hadn’t been saved. I’ll try that again!
Thanks for all the help but I’m officially giving up.
The flimsy nature of the emonesp connectors and the need for me to keep removing it to try insert the programmer and faff about with sending serial commands led to the inevitable and the connectors on the emonesp snapped.
Guess I’ll be sticking to the radio connection instead.
I don’t have an ESP8266, so I don’t know what the connector on that end is like. If it’s what I think, then maybe I’m very gentle with those sorts of things, because I’ve never snapped the pins on the emonTx, emonTH, emonGLCD, or even inside the emonPi, and I’m plugging a programmer into something many times every day. (e.g. I had to transfer my programmer to a different emonTx to grab that text I posted above.)
However, the emonTx was never designed to have a WiFi module added, so it always looked exactly like it was - something that came along later.
There’s a problem there. At present, if the (genuine) receive pin on the emonTx is connected, rogue data from the ESP8266, sent as I understand it as part of it’s start-up / Welcome message, destroys parts of the configuration settings of the emonTx.
If you are going to do that, it wants if at all possible to be the same as the emonPi front-end configuration that I’m working on - which if the ESP8266 is bi-directional - could be done inside emonhub.conf - like the emonPi will be (if it can be made to work).
