NIBE F2040 short cycling
I am new to the forum under the name Camelot. I cannot see how to post on the above subject. I must be missing something. Apologies.
Camelot
Welcome, Mike, to the OEM forum.
I can’t see that Topic exactly, and it looks as if you haven’t been here long enough to have gained that privilege. (This is just how our forum software works.) I’ve instead made your PM “public”, which amounts to the same thing - just that the Topic will start with a different message to the one you intended, and this response to it.
Is this the topic you were wanting to reply to?
Click on the blue link above and look for the blue “Reply” button at the bottom of the page.
Hi Tim,
Very close. I have posted a “Reply”. I hope that is the correct protocol.
Regards
Mike
I’ll lock this topic now - we don’t want near duplicates, it confuses everybody. Tim or I can reopen it if needs be.
It is indeed.
If you want to reply to a specific post, use the grey “Reply” at the bottom of the Post instead. It still goes onto the end, but links back to the post you are replying to.
