Hi Guys,
I’m so pleased to find your org, I’m completely in the dark about my power consumption and heatpump behaviour and your solutions look like they will help enormously, so thanks up front for just being there!
I have 2 heatpumps, several immersions, a huge electricity bill, and quite poor data from the heat pump controller (ok virtually none), and NO smart connectivity from the controller to anything (Nu-Heat say it won’t ever talk to anything).
I’m seeing two phases to my needs, partially because of my knowledge gaps & fear of the unknown.
- Just power monitoring, probably at least 4 inputs, possibly more.
- It’s heat pumps so I ought to be thinking about the heatpump monitoring (except my lack of understanding of it & how to monitor it).
Stage 1 looks quite straightforward, as long as I can find the power input wires on the relevant boxes, (getting advice from Nu-Heat about that, so optimistic). So that looks relatively straightforward & I’m looking forward to that. (Local database not cloud!).
Stage 2 is less clear to me. I could do with some pointers to documents on what to monitor, and how. I don’t believe the Grunfoss circulation pumps will provide any data, so how can I find the pressure drop (is that necessary?). The Hitachi heat pumps seem to have a display which (if you hit the little “i” button will scroll through Temperatures out & return etc) but no visible interface port.
I’m a bit lost with the concepts really, so would really appreciate some nudges in the right direction. Assuming the project is still live.
I’m an old techie so building the kit & doing a bit of soldering is not an area of worry! I have networking everywhere (wireless and wired), I’ve also built dozens of raspberry pi projects, so that holds no fear. It’s just the interface to the heat pump which I’m in the dark about.
Ooh - and I would be very interested in noting any temperature loss between the heatpumps & the house manifolds, if that’s poss. The heat pumps are in the garage.
Hope to hear from you in the fullness of time, there’s no hurry I have a lot on my plate currently, so it’s a new year project.
Thanks in advance
Lee
stoopidtechie
