Thank you Paul, this is great - gives enough continuous feedback to fault-find. (Which consisted of swapping A/B terminals back to where they were in the first place. Yes, I hear your ‘told you so’…)
Now getting good readings via the script, but still nothing in emonhub.
A snip from terminal:
1611301633.5775619It's time to read
1611301633.5775619We're still connected
1611301633.5775619We read the device and got: {'total_demand_current': 0.37746480107307434, 'maximum_total_demand_current': 0.4836726188659668, 'total_energy_active': 1.0, 'total_energy_reactive': 3.239000082015991}
1611301633.5775619total_demand_current: 0.37746480107307434
1611301633.5775619maximum_total_demand_current: 0.4836726188659668
1611301633.5775619total_energy_active: 1.0
1611301633.5775619total_energy_reactive: 3.239000082015991
1611301643.6536613It's time to read
1611301643.6536613We're still connected
1611301643.6536613We read the device and got: {'total_demand_current': 0.37749338150024414, 'maximum_total_demand_current': 0.4836726188659668, 'total_energy_active': 1.0, 'total_energy_reactive': 3.239000082015991}
1611301643.6536613total_demand_current: 0.37749338150024414
1611301643.6536613maximum_total_demand_current: 0.4836726188659668
1611301643.6536613total_energy_active: 1.0
1611301643.6536613total_energy_reactive: 3.239000082015991
1611301653.732548It's time to read
1611301653.732548We're still connected
and from emonhub after restarting
2021-01-22 07:42:46,386 INFO MainThread Exiting hub...
2021-01-22 07:42:47,314 DEBUG SDM120 []
2021-01-22 07:42:47,416 INFO MainThread Exit completed
2021-01-22 07:49:29,162 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-01-22 07:49:29,163 INFO MainThread Opening hub...
2021-01-22 07:49:29,163 INFO MainThread Logging level set to DEBUG
2021-01-22 07:49:29,164 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-01-22 07:49:29,165 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-01-22 07:49:31,176 INFO MainThread RFM2Pi device firmware version: OK
2021-01-22 07:49:31,177 INFO MainThread RFM2Pi device current settings: 23 21 0 0 0 201 3 31 0 1 0 0 0 (-64)
2021-01-22 07:49:31,178 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-01-22 07:49:32,180 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-01-22 07:49:33,182 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-01-22 07:49:34,184 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-01-22 07:49:35,186 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-01-22 07:49:36,189 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-01-22 07:49:36,190 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-01-22 07:49:36,191 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-01-22 07:49:36,196 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-01-22 07:49:36,197 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-01-22 07:49:36,198 INFO MainThread Setting MQTT node_format_enable: 1
2021-01-22 07:49:36,199 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-01-22 07:49:36,199 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-01-22 07:49:36,201 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-01-22 07:49:36,203 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-01-22 07:49:36,204 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-01-22 07:49:36,205 WARNING MainThread Setting emoncmsorg apikey: obscured
2021-01-22 07:49:36,206 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-01-22 07:49:36,206 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-22 07:49:36,207 INFO MainThread Setting emoncmsorg senddata: 1
2021-01-22 07:49:36,208 INFO MainThread Setting emoncmsorg sendstatus: 1
2021-01-22 07:49:36,209 INFO MainThread Creating EmonHubSDM120Interfacer 'SDM120'
2021-01-22 07:49:36,219 INFO MainThread Connecting to SDM120 device=/dev/ttyUSB0 baud=2400
2021-01-22 07:49:36,221 INFO MainThread Setting SDM120 read_interval: 10
2021-01-22 07:49:36,222 INFO MainThread Setting SDM120 nodename: SDM120
2021-01-22 07:49:36,222 INFO MainThread Setting SDM120 prefix:
2021-01-22 07:49:36,223 DEBUG MainThread Setting SDM120 pubchannels: ['ToEmonCMS']
2021-01-22 07:49:36,313 DEBUG RFM2Pi 1 NEW FRAME : OK 5 183 253 234 255 161 253 112 93 0 0 0 0 0 0 0 0 0 0 0 0 153 115 1 0 (-0)
2021-01-22 07:49:36,315 DEBUG RFM2Pi 1 Timestamp : 1611301776.313008
2021-01-22 07:49:36,315 DEBUG RFM2Pi 1 From Node : 5
2021-01-22 07:49:36,316 DEBUG RFM2Pi 1 Values : [-585, -22, -607, 239.20000000000002, 0, 0, 0, 0, 0, 0, 95129]
2021-01-22 07:49:36,316 DEBUG RFM2Pi 1 Sent to channel(start)' : ToEmonCMS
2021-01-22 07:49:36,317 DEBUG RFM2Pi 1 Sent to channel(end)' : ToEmonCMS
2021-01-22 07:49:36,420 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-22 07:49:36,502 INFO MQTT Connecting to MQTT Server
2021-01-22 07:49:36,524 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-22 07:49:36,607 INFO MQTT connection status: Connection successful
2021-01-22 07:49:36,608 DEBUG MQTT CONACK => Return code: 0
2021-01-22 07:49:36,610 DEBUG emoncmsorg Buffer size: 1
2021-01-22 07:49:36,628 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-22 07:49:36,710 INFO MQTT on_subscribe
2021-01-22 07:49:36,732 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-22 07:49:37,040 DEBUG RFM2Pi 2 NEW FRAME : OK 5 186 253 235 255 165 253 72 93 0 0 0 0 0 0 0 0 0 0 0 0 155 115 1 0 (-0)
2021-01-22 07:49:37,043 DEBUG RFM2Pi 2 Timestamp : 1611301777.040672
2021-01-22 07:49:37,044 DEBUG RFM2Pi 2 From Node : 5
2021-01-22 07:49:37,044 DEBUG RFM2Pi 2 Values : [-582, -21, -603, 238.8, 0, 0, 0, 0, 0, 0, 95131]
2021-01-22 07:49:37,045 DEBUG RFM2Pi 2 Sent to channel(start)' : ToEmonCMS
2021-01-22 07:49:37,046 DEBUG RFM2Pi 2 Sent to channel(end)' : ToEmonCMS
2021-01-22 07:49:37,113 DEBUG MQTT Publishing: emon/emonpi/power1 -582
2021-01-22 07:49:37,115 DEBUG MQTT Publishing: emon/emonpi/power2 -21
2021-01-22 07:49:37,117 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -603
2021-01-22 07:49:37,118 DEBUG MQTT Publishing: emon/emonpi/vrms 238.8
2021-01-22 07:49:37,120 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-22 07:49:37,122 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-22 07:49:37,124 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-22 07:49:37,126 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-22 07:49:37,128 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-22 07:49:37,130 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-22 07:49:37,132 DEBUG MQTT Publishing: emon/emonpi/pulsecount 95131
2021-01-22 07:49:37,133 INFO MQTT Publishing 'node' formatted msg
2021-01-22 07:49:37,134 DEBUG MQTT Publishing: emonhub/rx/5/values -582,-21,-603,238.8,0,0,0,0,0,0,95131
2021-01-22 07:49:41,977 DEBUG RFM2Pi 4 NEW FRAME : OK 5 184 253 234 255 162 253 114 93 0 0 0 0 0 0 0 0 0 0 0 0 158 115 1 0 (-0)
2021-01-22 07:49:41,980 DEBUG RFM2Pi 4 Timestamp : 1611301781.977602
2021-01-22 07:49:41,981 DEBUG RFM2Pi 4 From Node : 5
2021-01-22 07:49:41,981 DEBUG RFM2Pi 4 Values : [-584, -22, -606, 239.22, 0, 0, 0, 0, 0, 0, 95134]
2021-01-22 07:49:41,982 DEBUG RFM2Pi 4 Sent to channel(start)' : ToEmonCMS
2021-01-22 07:49:41,982 DEBUG RFM2Pi 4 Sent to channel(end)' : ToEmonCMS
2021-01-22 07:49:42,076 DEBUG MQTT Publishing: emon/emonpi/power1 -584
2021-01-22 07:49:42,077 DEBUG MQTT Publishing: emon/emonpi/power2 -22
2021-01-22 07:49:42,079 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -606
2021-01-22 07:49:42,080 DEBUG MQTT Publishing: emon/emonpi/vrms 239.22
2021-01-22 07:49:42,082 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-22 07:49:42,083 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-22 07:49:42,085 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-22 07:49:42,087 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-22 07:49:42,088 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-22 07:49:42,090 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-22 07:49:42,091 DEBUG MQTT Publishing: emon/emonpi/pulsecount 95134
2021-01-22 07:49:42,093 INFO MQTT Publishing 'node' formatted msg
2021-01-22 07:49:42,093 DEBUG MQTT Publishing: emonhub/rx/5/values -584,-22,-606,239.22,0,0,0,0,0,0,95134
2021-01-22 07:49:47,028 DEBUG RFM2Pi 5 NEW FRAME : OK 5 188 253 234 255 166 253 115 93 0 0 0 0 0 0 0 0 0 0 0 0 161 115 1 0 (-0)
2021-01-22 07:49:47,031 DEBUG RFM2Pi 5 Timestamp : 1611301787.028673
2021-01-22 07:49:47,032 DEBUG RFM2Pi 5 From Node : 5
2021-01-22 07:49:47,032 DEBUG RFM2Pi 5 Values : [-580, -22, -602, 239.23000000000002, 0, 0, 0, 0, 0, 0, 95137]
2021-01-22 07:49:47,033 DEBUG RFM2Pi 5 Sent to channel(start)' : ToEmonCMS
2021-01-22 07:49:47,033 DEBUG RFM2Pi 5 Sent to channel(end)' : ToEmonCMS
2021-01-22 07:49:47,152 DEBUG MQTT Publishing: emon/emonpi/power1 -580
2021-01-22 07:49:47,153 DEBUG MQTT Publishing: emon/emonpi/power2 -22
2021-01-22 07:49:47,155 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -602
2021-01-22 07:49:47,157 DEBUG MQTT Publishing: emon/emonpi/vrms 239.23000000000002
2021-01-22 07:49:47,158 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-22 07:49:47,159 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-22 07:49:47,161 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-22 07:49:47,162 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-22 07:49:47,164 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-22 07:49:47,165 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-22 07:49:47,167 DEBUG MQTT Publishing: emon/emonpi/pulsecount 95137
2021-01-22 07:49:47,168 INFO MQTT Publishing 'node' formatted msg
2021-01-22 07:49:47,169 DEBUG MQTT Publishing: emonhub/rx/5/values -580,-22,-602,239.23000000000002,0,0,0,0,0,0,95137
2021-01-22 07:49:47,419 DEBUG SDM120 []
2021-01-22 07:49:51,974 DEBUG RFM2Pi 7 NEW FRAME : OK 5 189 253 235 255 168 253 184 93 0 0 0 0 0 0 0 0 0 0 0 0 163 115 1 0 (-0)
2021-01-22 07:49:51,976 DEBUG RFM2Pi 7 Timestamp : 1611301791.973919
2021-01-22 07:49:51,976 DEBUG RFM2Pi 7 From Node : 5
2021-01-22 07:49:51,977 DEBUG RFM2Pi 7 Values : [-579, -21, -600, 239.92000000000002, 0, 0, 0, 0, 0, 0, 95139]
2021-01-22 07:49:51,977 DEBUG RFM2Pi 7 Sent to channel(start)' : ToEmonCMS
2021-01-22 07:49:51,977 DEBUG RFM2Pi 7 Sent to channel(end)' : ToEmonCMS
2021-01-22 07:49:52,108 DEBUG MQTT Publishing: emon/emonpi/power1 -579
2021-01-22 07:49:52,110 DEBUG MQTT Publishing: emon/emonpi/power2 -21
2021-01-22 07:49:52,111 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -600
2021-01-22 07:49:52,113 DEBUG MQTT Publishing: emon/emonpi/vrms 239.92000000000002
2021-01-22 07:49:52,114 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-22 07:49:52,116 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-22 07:49:52,117 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-22 07:49:52,119 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-22 07:49:52,120 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-22 07:49:52,121 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-22 07:49:52,123 DEBUG MQTT Publishing: emon/emonpi/pulsecount 95139
2021-01-22 07:49:52,125 INFO MQTT Publishing 'node' formatted msg
2021-01-22 07:49:52,126 DEBUG MQTT Publishing: emonhub/rx/5/values -579,-21,-600,239.92000000000002,0,0,0,0,0,0,95139
2021-01-22 07:49:57,006 DEBUG RFM2Pi 8 NEW FRAME : OK 5 187 253 234 255 165 253 68 93 0 0 0 0 0 0 0 0 0 0 0 0 166 115 1 0 (-0)
2021-01-22 07:49:57,008 DEBUG RFM2Pi 8 Timestamp : 1611301797.005850
2021-01-22 07:49:57,009 DEBUG RFM2Pi 8 From Node : 5
2021-01-22 07:49:57,009 DEBUG RFM2Pi 8 Values : [-581, -22, -603, 238.76, 0, 0, 0, 0, 0, 0, 95142]
2021-01-22 07:49:57,010 DEBUG RFM2Pi 8 Sent to channel(start)' : ToEmonCMS
2021-01-22 07:49:57,011 DEBUG RFM2Pi 8 Sent to channel(end)' : ToEmonCMS
2021-01-22 07:49:57,164 DEBUG MQTT Publishing: emon/emonpi/power1 -581
2021-01-22 07:49:57,166 DEBUG MQTT Publishing: emon/emonpi/power2 -22
2021-01-22 07:49:57,168 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -603
2021-01-22 07:49:57,169 DEBUG MQTT Publishing: emon/emonpi/vrms 238.76
2021-01-22 07:49:57,171 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-22 07:49:57,173 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-22 07:49:57,174 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-22 07:49:57,176 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-22 07:49:57,177 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-22 07:49:57,178 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-22 07:49:57,179 DEBUG MQTT Publishing: emon/emonpi/pulsecount 95142
2021-01-22 07:49:57,181 INFO MQTT Publishing 'node' formatted msg
2021-01-22 07:49:57,181 DEBUG MQTT Publishing: emonhub/rx/5/values -581,-22,-603,238.76,0,0,0,0,0,0,95142
2021-01-22 07:49:57,401 DEBUG SDM120 []
2021-01-22 07:50:02,048 DEBUG RFM2Pi 10 NEW FRAME : OK 5 195 253 236 255 175 253 0 93 0 0 0 0 0 0 0 0 0 0 0 0 168 115 1 0 (-0)
2021-01-22 07:50:02,051 DEBUG RFM2Pi 10 Timestamp : 1611301802.048171
2021-01-22 07:50:02,051 DEBUG RFM2Pi 10 From Node : 5
2021-01-22 07:50:02,052 DEBUG RFM2Pi 10 Values : [-573, -20, -593, 238.08, 0, 0, 0, 0, 0, 0, 95144]
2021-01-22 07:50:02,052 DEBUG RFM2Pi 10 Sent to channel(start)' : ToEmonCMS
2021-01-22 07:50:02,054 DEBUG RFM2Pi 10 Sent to channel(end)' : ToEmonCMS
2021-01-22 07:50:02,321 DEBUG MQTT Publishing: emon/emonpi/power1 -573
2021-01-22 07:50:02,322 DEBUG MQTT Publishing: emon/emonpi/power2 -20
2021-01-22 07:50:02,323 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -593
2021-01-22 07:50:02,325 DEBUG MQTT Publishing: emon/emonpi/vrms 238.08
2021-01-22 07:50:02,326 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-22 07:50:02,327 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-22 07:50:02,328 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-22 07:50:02,330 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-22 07:50:02,332 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-22 07:50:02,333 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-22 07:50:02,334 DEBUG MQTT Publishing: emon/emonpi/pulsecount 95144
2021-01-22 07:50:02,335 INFO MQTT Publishing 'node' formatted msg
2021-01-22 07:50:02,336 DEBUG MQTT Publishing: emonhub/rx/5/values -573,-20,-593,238.08,0,0,0,0,0,0,95144
2021-01-22 07:50:06,621 DEBUG emoncmsorg Buffer size: 6
2021-01-22 07:50:06,989 DEBUG RFM2Pi 11 NEW FRAME : OK 5 191 253 233 255 168 253 241 92 0 0 0 0 0 0 0 0 0 0 0 0 171 115 1 0 (-0)
2021-01-22 07:50:06,991 DEBUG RFM2Pi 11 Timestamp : 1611301806.988850
2021-01-22 07:50:06,992 DEBUG RFM2Pi 11 From Node : 5
2021-01-22 07:50:06,993 DEBUG RFM2Pi 11 Values : [-577, -23, -600, 237.93, 0, 0, 0, 0, 0, 0, 95147]
2021-01-22 07:50:06,993 DEBUG RFM2Pi 11 Sent to channel(start)' : ToEmonCMS
2021-01-22 07:50:06,994 DEBUG RFM2Pi 11 Sent to channel(end)' : ToEmonCMS
2021-01-22 07:50:07,070 DEBUG MQTT Publishing: emon/emonpi/power1 -577
2021-01-22 07:50:07,071 DEBUG MQTT Publishing: emon/emonpi/power2 -23
2021-01-22 07:50:07,073 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -600
2021-01-22 07:50:07,074 DEBUG MQTT Publishing: emon/emonpi/vrms 237.93
2021-01-22 07:50:07,076 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-22 07:50:07,078 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-22 07:50:07,079 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-22 07:50:07,081 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-22 07:50:07,082 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-22 07:50:07,083 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-22 07:50:07,085 DEBUG MQTT Publishing: emon/emonpi/pulsecount 95147
2021-01-22 07:50:07,087 INFO MQTT Publishing 'node' formatted msg
2021-01-22 07:50:07,088 DEBUG MQTT Publishing: emonhub/rx/5/values -577,-23,-600,237.93,0,0,0,0,0,0,95147
2021-01-22 07:50:07,372 DEBUG SDM120 []
2021-01-22 07:50:12,038 DEBUG RFM2Pi 13 NEW FRAME : OK 5 189 253 233 255 166 253 224 92 0 0 0 0 0 0 0 0 0 0 0 0 173 115 1 0 (-0)
2021-01-22 07:50:12,040 DEBUG RFM2Pi 13 Timestamp : 1611301812.037661
2021-01-22 07:50:12,041 DEBUG RFM2Pi 13 From Node : 5
2021-01-22 07:50:12,042 DEBUG RFM2Pi 13 Values : [-579, -23, -602, 237.76, 0, 0, 0, 0, 0, 0, 95149]
2021-01-22 07:50:12,042 DEBUG RFM2Pi 13 Sent to channel(start)' : ToEmonCMS
2021-01-22 07:50:12,043 DEBUG RFM2Pi 13 Sent to channel(end)' : ToEmonCMS
2021-01-22 07:50:12,236 DEBUG MQTT Publishing: emon/emonpi/power1 -579
2021-01-22 07:50:12,237 DEBUG MQTT Publishing: emon/emonpi/power2 -23
2021-01-22 07:50:12,239 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -602
2021-01-22 07:50:12,240 DEBUG MQTT Publishing: emon/emonpi/vrms 237.76
2021-01-22 07:50:12,242 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-22 07:50:12,243 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-22 07:50:12,245 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-22 07:50:12,247 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-22 07:50:12,248 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-22 07:50:12,250 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-22 07:50:12,251 DEBUG MQTT Publishing: emon/emonpi/pulsecount 95149
2021-01-22 07:50:12,253 INFO MQTT Publishing 'node' formatted msg
2021-01-22 07:50:12,253 DEBUG MQTT Publishing: emonhub/rx/5/values -579,-23,-602,237.76,0,0,0,0,0,0,95149
So, there’s data, but emonhub isn’t reading it.
