I have a emonTX v3 connected to the solar panels, and I would like to build a Raspberry Pi based monitoring hub. My understanding is that I will need the following hardware:
- Raspberry Pi (with SD card)
- 433MHZ receiver
My questions are:
- which version of Raspberry Pi do I need for emonBase? Is it Raspoberry Pi 4?
- Will emonTX v3 work with the latest emonBase?
- On the receiver side, I was planning to buy “RFM69SPI 433Mhz Transceiver”, but that is out of stock. Is " JeeLink RFM69CW to USB Transceiver 433Mhz" would be good for me?
- And if yes, which firmware do I need to order JeeLink with? Standard (RF encryption) or Existing hardware compatibility (<2022)?
Please let me know if you need more info ![]()
