Hello,
Recently moved into a house that has a heatpump and solar panels, having previous only been in a house with a combi boiler. The heatpump is a Samsung RC160MHXEA connected to two external thermostats, one is a dumb rotating wall thermostat for the underfloor heating and the other is a programmable room thermostat for the radiators.
Trying to understand how to run the heat pump most efficiently, whilst keeping the house warm and minimising electricity usage. I currently don’t have any active monitoring on the heat pump (have ordered a bunch of stuff from here, but its out of stock at the moment), so my current monitoring is from purely reading our electricity meter.
In the 28 days we have been here, we have used around 1200 kWh of electricity, which is about £300! Where we used to live, our combined electricity and gas was around £100 a month. Once we noticed this usage a few days ago, I start keeping a close eye on the electricity meter. After a couple of nights in a row of using 17kWh overnight (between around 21:30 and 0700), on the next night I just turned off the heatpump completely. That night (between the same hours) we only used 4kWh. So the heat pump is obviously the biggest draw.
I understand some of the theory of heat pumps and that you want to try and minimise the amount of times they start / stop as this process uses a lot of electricity (when I turned the heat pump back on after it being off all night, it used around 5kWh in less than an hour which makes sense). But what does being “on” actually mean? With the heat pump constantly making a noise? (i.e with the compressor on and the fans spinning). On our heat pump controls, we have two icons, one is for when the compressor is on (when the outdoor unit turns on and is making lots of noise) and the other is for the “water circulation pump” being on. Do we just want the “water circulation pump” to be on, but not the compressor? or both to maximise efficiency / energy usage?
I think I also understand the theory that you want to have the “flow” temperature as low as possible, whilst maintaining a comfortable temperature. Our heat pump runs in weather compensation mode and there are bunch of different numbers and offsets I know I can configure for this.
I have read through this article: 3 Steps to Maximise Your Heat Pump (or Boiler) Efficiency - HeatGeek which explains a “method” of determining what the correct flow temperatures need to be for your own house. Does this make sense? I had a go at following this yesterday evening. I opened up all the radiator valves to full and set the radiator thermostat to 23c. I reduced the minimum flow temperature on the weather compensation setting and the heat pump came on and stayed permanently on (making noise, compressor on etc) and during the evening the heat settled at 21c and didn’t rise, despite the thermostat being set to 23c. I left this running overnight (heat pump constantly going, which it has not done before since we moved in, its always on for a bit, off for a bit etc) and when I woke up, we had used around 20kWh. So more than before I started messing with it. The house was warmer than we would like (22.5c, target would be 21c) overnight, so I probably need to make some more adjustments to the flow temperature to find the “ideal” settings, however with the increased usage, I panicked and set the thermostat back to 21c and the heat pump turned off. It’s now back to the compressor not being on all the time. Was that the correct thing to do? Is having it constantly on (24/7 365 days a year?!) the more efficient / least energy consuming way to use it or? or should I just be setting the room thermostat to 21c and let it turn it on and off as it deems necessary?
I hope the above makes sense! Please shout if I can provide any other info that would be useful. Just trying to understand if ours is running really inefficiently or if these sorts of energy usage is expected (I was under the impression that heat pumps were supposed to save you money on your energy bills!) Any advice / assistance is greatly appreciated!
EDIT: I have bolded my specific questions, in case anyone can jump in on those. But very thankful for any advice / input at all!
lowering the flow temp is the best option I think
