I’m developing my own nodes with RFM69 modules and decided to not use the rfm12 JeeLabs library and use a RFM69 specific one to gain added functionality of the new hardware. This will make new RF nodes incompatible with the older.
So i’m building a generic gateway RF->TCP that can pass pairs of name->value data to the emoncms input API.
Now need to create a message payload format and re-think the concept of node id to support any number of devices.
1 - I’m thinking on using msgpack: http://msgpack.org/.
2 - Use serial number / guid / mac, or just some setup phase pre-roll authentication?
3 - Size limitation, each data package on the air must be < 63bytes.
4 - Large multi-package messages is a desired option.
5 - Support for out-band data like RSSI, battery level, etc
6 - Support bidirectional data for remote config / firmware update?
Any one want to give inputs on this and about other data encoding formats to use that can be implemented on an arduino?
