I installed emonpi yesterday and have a 2nd ct clamp for my pv feed. However, I am unable to log any data whatsoever.
Looking at the logs, I can see in the EmonCMS log the message:
‘ERROR|index.php|Not Authenticated|device/list’
Is this preventing the logging? If so, how do I resolve the problem please?
Were both CTs plugged in before you powered the EmonPI?
This just means you were not logged into emocms. You can still do some things even once the system has logged you out so it is not always immediately obvious. Click on ‘Admin’ and it may then ask you to log in.
Thanks. I’ve fiddled and found I was misunderstanding the feeds. I’ve finally found the template for setting up the inputs>feeds, so all slowly making sense.
