New install stable Image on SSD - no access
Hello, I tried to install on my SSD this Image:
emonSD-10Nov22 (Stable)
from
https://docs.openenergymonitor.org/emonsd/download.html
Writing with etcher. After start the pi there is a failure:
You are in emergency mode…
Cannot open access to console, the root account is locked.
I think the problem is the image is for a sd card and I installed it to an 128GB SSD (plugged via SATA to USB adapter) on an Pi400.
I checked the internet for the issue. Adjust the fstab.
But what should I change?
I thought an SSD is a sda, sdb or something and no mmc…
proc            /proc           proc    defaults          0       0
/dev/mmcblk0p1  /boot           vfat    defaults          0       2
/dev/mmcblk0p2  /               ext4    defaults,noatime,nodiratime  0  1
/dev/mmcblk0p3  /var/opt/emoncms   ext2    defaults,noatime,nodiratime  0  2
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
tmpfs           /tmp                   tmpfs   nodev,nosuid,size=30M,mode=1777 0  0
tmpfs           /var/tmp               tmpfs   nodev,nosuid,size=1M,mode=1777  0  0
tmpfs           /var/lib/php/sessions  tmpfs   nodev,nosuid,size=1M,mode=1777  0  0
The SD card is rather particular and copies a specific fstab file, so no, the image will not work with an SSD.
My advice is to follow the self install using the emonScript. Pretty sure the RPi imager copes with SSDs. I think you will still need to create a dummy partition first still though and then expand the partitions as per the instructions for the SD Card.
https://docs.openenergymonitor.org/emonsd/install.html
OK thanks. I will try it by Scripts
