New install of EmonCMS on Ubuntu 20LTS
Trying to install EmonCMS on Ubuntu 20.04LTS. The install script fails with this error:
PHP Warning:  chdir(): No such file or directory (errno 2) in /opt/openenergymonitor/EmonScripts/common/emoncmsdbupdate.php on line 8
PHP Warning:  require(process_settings.php): failed to open stream: No such file or directory in /opt/openenergymonitor/EmonScripts/common/emoncmsdbupdate.php on line 9
PHP Fatal error:  require(): Failed opening required 'process_settings.php' (include_path='.:/usr/share/php') in /opt/openenergymonitor/EmonScripts/common/emoncmsdbupdate.php on line 9
When I checked /var/www there was no emoncms folder.
Any idea what’s wrong?
@ishtangli, I shared my Ubuntu install notes in this topic. Hopefully my notes are of some use…
How long ago was this install?
I was able to successfully install it using the script last year. Must have been some significant change since then.
I’ve gotten the system to partially run by manually doing a git clone of emoncms to /var/www and changing the default passwords in settings.ini to match the ones in config.ini.
I still have 2 red lights under System Info: feedwriter and demandshaper.
Any ideas?
I was able to setup a fresh install with 0 hassle (2021 edition). Here are the steps:
  1. Install Ubuntu 20.04LTS. When asked to create a user, use ā€œpiā€
  2. sudo echo $USER’ ALL=(ALL) NOPASSWD: ALL’ | sudo tee /etc/sudoers.d/$USER && sudo chmod 0440 /etc/sudoers.d/$USER
  3. wget https://raw.githubusercontent.com/openenergymonitor/EmonScripts/master/install/init.sh
    chmod +x init.sh && ./init.sh
  4. say Y when asked to review the config
  5. cd /opt/openenergymonitor/EmonScripts/install/
    nano config.ini
  6. Set emonSD_pi_env=0
  7. replace all ā€œstableā€ with ā€œmasterā€
  8. Save and quit
  9. ./main.sh
You can now access the server through the IP address. Everything works out of the box except for update which gives the ā€œinvalid serial portā€ error.
update App throws a ā€œconnection errorā€
Thanks @ishtangli that should now be fixed! Though you may have to manually run the following commands to get past the issue:
git pull
cd /var/www/emoncms
git pull
Worked perfectly. Thanks.
Now my only problem is in the app
Get a connection error after 10 seconds which wasnt an issue on my 2019 installation (ubuntu 18).
I get the following error when executing the first instruction:
-bash: syntax error near unexpected token `(’
When I run the commands using ā€˜sudo’ (since I get an error on the first instruction), I receive the following error on the last step:
./main.sh: 90: /EmonScripts/install/non_emonsd.sh: not found
I was able to get a clean install using these steps on July 27th.
Which instruction from where?
Here? https://github.com/openenergymonitor/EmonScripts/blob/master/install/readme.md#ubuntu
Thanks for the link. That works properly. I was using the text from the Jul 19 post.
