New Arotherm+ install with noisy circulation pump - suggestions
Hi all, new Arotherm plus system installed recently, performance very good, Arotherm is virtually silent, but slight niggle with the circulation pump in the airing cupboard which has a faint whining sound when nearby and the system flow generates a continuous, slight rushing sound audible throughout the house.
Any tips? It’s bearable during the day, but screws up sleep patterns at night so need to do something before insanity takes over!
Good chance it’s air in the system, so may need a good bleed, as you have a second pump is there a buffer also? They normally have a bleed point and also look at the upstairs radiators and see if you have air in those. Or get the installer back to sort it out! It should be silent.
Did the installer close down the lockshields on the radiators? Mine did and it made a right din. I opened them straight back up again.
(It was done for “balancing” but in reality the radiators were all about the same temperature with the valves wide open, so I’m not sure why the installer did what he did)
Balancing is a dark art, and comes down to more than just how warm the radiator feels, but so long as you are comfortable with the temperature of each room then it’s working fine.
My question is what is this pump doing. The circulator is (normally) built into the outdoor unit, so what is the function of the pump you speak of.
The heating circuit flows through a large buffer and with the heatpump one side and the radiators the other. The noise is from the radiators side which has it’s own circulation pump.
The obvious answer is - remove the buffer and secondary pump. Its almost certainly hurting your COP, almost certainly superfluous, and will certainly make fault diagnosis when faults do occur more difficult.
Unless there is a very good reason for a buffer, which is rare in domestic properties, they should not be fitted. If you need extra system volume for defrost, simply replumb it as a 2 port volumiser in either flow or return but not both.
Did your installer tell you what the buffer was for and/or is there anything extreme/odd about your property?
