I’m looking for a simple solution to track my net metering (at the connection to the grid). I was trying to use the My Electric app, and it is almost perfect for my use case except that the graphs specifically don’t show negative values. I’ve got the use and the use_kwh values configured and the numbers are doing what they need to (use shows - when I’m sending to the grid, and use_kwh decreases when I’m sending back to the grid and increases when I’m pulling for the grid). Is there an easy way to show negative graph values on the app, or does anyone have a suggestion on how I might make this work ?
Thanks,
-Rob
