I am setting up a new RPI4 and have flashed and loaded the latest SD card to a 64GB card. After using it I find that my / directory is at 93% although other directories are ok. I have tried moving to a 128GB card but it only moves the original image as 64GB and the nearly full / directory. Is there a way to resize the root before flashing the card since raspi-config won’t work because there are three partitions? I am not skilled in Linux and need help. I tried the resizing instructions in your archive but couldn’t get it to work. Thanks in advance. Cheers.
Bob
PS I have another earlier RPI4 running fine with a 2021 image
pi@emonpi:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
udev 1.6G 0 1.6G 0% /dev
tmpfs 760M 9.5M 750M 2% /run
/dev/mmcblk0p2 6.4G 5.6G 478M 93% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 5.0M 16K 5.0M 1% /run/lock
tmpfs 1.0M 0 1.0M 0% /var/lib/php/sessions
tmpfs 128M 0 128M 0% /var/tmp
tmpfs 30M 428K 30M 2% /tmp
/dev/mmcblk0p1 510M 67M 444M 13% /boot/firmware
/dev/mmcblk0p3 52G 3.3G 46G 7% /var/opt/emoncms
log2ram 50M 22M 29M 43% /var/log
tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service
tmpfs 1.0M 0 1.0M 0% /run/credentials/[email protected]
tmpfs 380M 12K 380M 1% /run/user/1000
mmcblk0 179:0 0 59.5G 0 disk
├─mmcblk0p1 179:1 0 512M 0 part /boot/firmware
├─mmcblk0p2 179:2 0 6.5G 0 part /var/log.bak
└─mmcblk0p3 179:3 0 52.4G 0 part /var/opt/emoncms
zram0 254:0 0 2G 0 disk [SWAP]
