borpin
(Brian Orpin)
21
This is the crucial bit of info!
Hello @borpin
May be! But I just can not see this message completely. And it is not recorded in the logs. How and where can I see it?
Hmm. From apache24-error_log
2020-01-06T08:58:09+02:00 DS3615HOME [Mon Jan 06 08:58:09.955111 2020] [proxy_fcgi:error] [pid 17473:tid 140685126588160] [client 192.168.1.200:35066] AH01071: Got error 'PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(/usr/sbin/mosquitto) is not within the allowed path(s): (/tmp:/var/services/tmp:/var/services/web:/var/services/homes:/var/lib/phpfiwa:/var/lib/phpfina:/var/lib/phptimeseries:/var/log/emoncms) in /volume1/web/emoncms/Modules/admin/admin_model.php on line 318\nPHP message: PHP Notice: Undefined index: total in /volume1/web/emoncms/Modules/admin/admin_main_view.php on line 304\nPHP message: PHP Notice: Undefined index: free in /volume1/web/emoncms/Modules/admin/admin_main_view.php on line 306\n', referer: http://192.168.1.254/emoncms/feed/view
I am not use mosquitto
borpin
(Brian Orpin)
25
@Tehnoinstyle_Aleksey can you try this and see if it fixes the issue?
from Modules/admin/admin_model.php delete:
public static function mqtt_version() {
$v = '?';
if(strtoupper(substr(PHP_OS, 0, 3)) === 'WIN') {
$v = "n/a";
} else {
if (file_exists('/usr/sbin/mosquitto')) {
$v = exec('/usr/sbin/mosquitto -h | grep -oP \'(?<=mosquitto\sversion\s)[0-9.]+(?=\s*)\'');
return $v;
and paste:
} catch (Error $e) {
global $log;
$log->info(_('Issue checking /usr/sbin/mosquitto').' - '.$e->getMessage());
$v = "n/a";
return $v;
yes or no?
p.s. I’m sorry, but I really have little knowledge in the code.
borpin
(Brian Orpin)
27
NO!
The lines of the file above are collapsed - click on
to see it all.
Better to click on the 3 dots to the right, and View File.
$v = '?';
$v = "n/a";
} else {
try {
global $log;
$v = "n/a";
return $v;
thanks. I’m going to try now.
$v = '?';
$v = "n/a";
} else {
try {
global $log;
$v = "n/a";
return $v;
the same? only for 319 line:
2020-01-06T14:08:22+02:00 DS3615HOME [Mon Jan 06 14:08:22.465623 2020] [proxy_fcgi:error] [pid 18027:tid 140132736743168] [client 178.151.206.206:34582] AH01071: Got error 'PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(/usr/sbin/mosquitto) is not within the allowed path(s): (/tmp:/var/services/tmp:/var/services/web:/var/services/homes:/var/lib/phpfiwa:/var/lib/phpfina:/var/lib/phptimeseries:/var/log/emoncms) in /volume1/web/emoncms/Modules/admin/admin_model.php on line 319\nPHP message: PHP Notice: Undefined index: total in /volume1/web/emoncms/Modules/admin/admin_main_view.php on line 304\nPHP message: PHP Notice: Undefined index: free in /volume1/web/emoncms/Modules/admin/admin_main_view.php on line 306\n', referer: http://192.168.1.254/emoncms/feed/list
p.s. I have returned the original admin_model.php file so far.
borpin
(Brian Orpin)
30
@emrys, looks like there are various conditions that will create an issue on a Non-Pi system. But I’ve just notice this is a WARNING not an ERROR so Try/Catch does not help!
Is this line right? If I’m not mistaken it always evaluates to true?
[edit]
For mosquitto, why not check if the service is running first? If not running locally, it is pointless information.
emrys
(Emrys Roberts)
31
changed the try/catch for a custom error handler. this should catch (and log) the error if there is a directory restriction set for the install.
here’s what I changed…
direct link to commit:
[added try/catch block arround file_exists() code by emrysr · Pull Request #1495 · emoncms/emoncms · GitHub]
this was added to the original pull request
emrys
(Emrys Roberts)
32
@borpin, yes this snippet seems to always return true? (with the additional ‘@’ to suppress any php warnings)
if (@is_readable('/proc/cpuinfo') || true) {
unsure of the reason for this || true condition? only used on this line.
It’s the sort of trick I do when testing - I think you’ll only find out if you ask whoever put it there.
borpin
(Brian Orpin)
34
Ah, so could we use that trick to suppress the warnings on the file_exists call as well? (useful to know).
@TrystanLea @glyn.hudson my feeling this should not be there!
emrys
(Emrys Roberts)
35
@borpin - I don’t like using the @ operator to suppress error messages. Better to use the custom error handler in the pull request to catch expected errors.
silently ignoring errors wont help anyone to fix the issue.
borpin
(Brian Orpin)
36
Don’t disagree, just suggest that we are consistent
Happy for it to be changed. Let me know when your ready @emrys for changes to be merged.
emrys
(Emrys Roberts)
38
@TrystanLea - I think is ok to merge pull request (unless other changes needed):
borpin
(Brian Orpin)
39
I think it might be good to pull this into a new branch on the emoncms repo for a bit more testing to see if it breaks other things. I’d like to see a ‘dev’ branch for this sort of thing.
A bit OT but the always ‘true’ condition needs sorting and lets be consistent on the use of @. if warnings can be caught then let’s do so.
