Need a little help here with a few things;
I run an odd sized bank. I have 17S2P that I wish to monitor. How do I best do this? I currently have 17 modules hooked up and running, 0/0-1/0 and thats working just fine, sorta. How do I add my other 17S bank? Do I need to run a second loop with its own controller and IP address?
How can I can the volatge RANGE on the maiin screen? I run LiFePO4 and my MAX is 3.65vdc, so I would like the max voltage say 3.75vdc. The reason is that screen is not well used all being at the bottom. Is there some code that I can edit, or is this hard coded? and option on the settings screen would be nice.
I am getting some errors, and I am not sure why, it works mostly, hangs up sometimes. I can Leave a window open to the settings page in the background so I have access to the reset button, and that works most times. When I say hang up, I mean that the busy circle in the middle just keeps rotating and never fully loads.
on my modules page I see many bad packets on some but not all modules heres a clip;
Bad packet
count
Bank Module Voltage V. Min V. Max Temp Int °C Temp Ext °C Bypass PWM Bad packet count
0 0 3.321 3.316 3.332 13 0 1
0 1 3.344 3.339 3.350 13 0 3
0 2 3.318 3.318 3.323 13 0 0
0 3 3.321 3.316 3.326 12 0 8
0 4 3.314 3.309 3.324 12 0 12
0 5 3.319 3.314 3.325 12 0 0
0 6 3.310 3.305 3.315 12 0 3
0 7 3.315 3.310 3.320 12 0 2
0 8 3.325 3.314 3.325 11 0 1
0 9 3.322 3.312 3.322 11 0 13
0 10 3.314 3.309 3.319 12 0 116
0 11 3.313 3.308 3.318 12 0 86
0 12 3.314 3.314 3.319 12 0 25
0 13 3.316 3.310 3.321 12 0 46
0 14 3.313 3.313 3.319 12 0 49
0 15 3.310 3.310 3.321 12 0 50
1 0 3.329 3.329 3.344 12 0 57
Notice that the mass of errors around cell 0/9. What is the likely cause of this?
Also, could you add a rule that uses the temp Int? This would be nice in addition to cell temp. Ie turn on a fan for high temp, or disable charging for cold cells etc.
Do the wires between the modules need to be twisted? If so how many twists per inch/cm?
Self powered controller? It there a possibility of including a small voltage reg to buck the pack voltage down to 5v? The other advantage is a controller based voltage sense.
Thats all I have for now.
PS Stuart, I have exposed my esp via a port forward so you can poke around if need be, PM me for the link so you can see the errors I am getting. Due to no security on the webpage I won’t post this publicly.
Thanks in advance, Michael.
