NA noob's oobe and questions (starting up the learning curve)
Do you mind posting some pictures of your setup? In the other “Use in North America” thread we had lots of questions about building/electrical code. Can the emonVS be inside the breaker panel? (Likely not.) Does it need to be in an enclosure with a disconnect? (Likely so.) What can we use between the breaker panel and the enclosure, Romex 12/3? Single conductor wire in a conduit?
It has been on my list of things to do to work with an electrician and try it out in my own panel and report back how it went. If you are willing to share your setup it would provide another datapoint. Thanks!
I’m going to start another topic called Getting into the North American Panel
