Hi there,
I’ve managed to get most of my data from the inverter (via Home Assistant) in to EmonCMS. I have struggled a little with the inverter and essentially had to work quite a bit out myself as to which registers to pull and what means what.
I have a Solis 5kw inverter, and was wondering which register, or later derived piece of information is it that feeds the ‘Cumulative solar generation used directly in kWh’ field in the app set up?
I don’t see anywhere that reports exclusively how much generated solar has been used, so is it a calculation usually? And, if so, could someone more enlightened than I please share it?
Thanks so much
