System: Vaillant aroTHERM Plus 12 kW, data pushed from Home Assistant via emoncms_history every 60 s (emoncms.org, heatpumpmonitor system 1425).
The My Heatpump app’s power view works fine (electric, flow, return, outside temperature all plot correctly). But the daily view and “Total since” show 0 kWh for both electricity and heat, and SCOP “–”. The daily view does create days, and shows outside temperature for each one.
Config:
- heatpump_elec_kwh → hp_elec_lifetime_kwh (PHPFina, 60 s, cumulative, currently ~526 kWh and rising)
- heatpump_heat_kwh → hp_heat_life_kwh (PHPFina, 60 s, cumulative, ~2,430 kWh)
- heatpump_elec → hp_elec_power_local (W)
- heatpump_heat → AUTO (unmapped deliberately; our heat power source was unreliable)
- flowT, returnT, outsideT mapped; daily pre-processor enabled; start date 0
Things tried: renamed two old, stale feeds that were called heatpump_elec_kwh and heatpump_heat_kwh (in case auto-select was grabbing them), then “Reload daily data”. Days rebuild, but kWh still 0.
Is the daily processor perhaps requiring a heat power feed, or something else I’ve missed? Screenshots attached.
