Mqtt interfacer gets no data
Hi, it does work after I change that filename hardcode to where that file sits on my install. I’m not sure where the install script puts that file and why the hardcode doesn’t look for it where the script puts it. I’ll make a github issue for it.
My reason for running standalone, is that I will be keeping data local only, and not using emoncms locally either. I will be using emonhub and mqtt to push data into rrdtool using something similar to this:
