Don’t see the option to generate an MQTT msg from a virtual feed. Is this deliberate ? Thx
Yes it’s only possible to generate MQTT messages from an input using the Publish to MQTT input process.
Virtual feeds only process data when you view the data, the calculations are done on the fly e.g when you open the graph of that virtual feed.
