MQTT broadcast to MQTT broker
Hi there.
Just bought a MQTT Wi-Fi Relay, and I have a question concerning the MQTT broadcast to a MQTT broker.
I installed a Mosquitto broker in the same network, but MQTT Wi-Fi Relay won’t publish anything. I already tried to use a iPhone app to simulate a publish, and everything worked fine.
Do I miss something?
Do I have a bad component?
HTTP access to read values works fine, only MQTT broadcast is not working properly.
I forget to mention, that I am using the last version of the Mosquitto broker v3.1
Just solved by a simple restart :wink:
Thanks anyway :grinning:
