I’m trying to monitor a fronius primo 5 with emoncms, I have confiured emonhub as is described here:
but after change ocnfig and restart always logfile is showing:
2018-12-07 19:17:04,171 INFO MainThread Exiting hub...
2018-12-07 19:17:04,398 INFO MainThread Exit completed
2018-12-07 19:17:07,702 INFO MainThread EmonHub emonHub emon-pi variant v2.1.1
2018-12-07 19:17:07,703 INFO MainThread Opening hub...
2018-12-07 19:17:07,705 INFO MainThread Creating EmonModbusTcpInterfacer 'ModbusTCP'
2018-12-07 19:17:07,706 ERROR MainThread Unable to create 'ModbusTCP' interfacer: global name 'pymodbus_found' is not defined
2018-12-07 19:17:07,707 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2018-12-07 19:17:09,713 WARNING MainThread Device communication error - check settings
2018-12-07 19:17:09,714 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2018-12-07 19:17:10,717 INFO MainThread Setting RFM2Pi group: 210 (210g)
2018-12-07 19:17:11,720 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2018-12-07 19:17:12,723 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2018-12-07 19:17:13,726 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2018-12-07 19:17:14,731 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2018-12-07 19:17:14,736 INFO MainThread Setting MQTT nodevar_format_enable: 1
2018-12-07 19:17:14,738 INFO MainThread Setting MQTT node_format_enable: 1
2018-12-07 19:17:14,739 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2018-12-07 19:17:14,741 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2018-12-07 19:17:14,743 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2018-12-07 19:17:14,744 INFO MainThread Setting emoncmsorg senddata: 1
2018-12-07 19:17:14,745 WARNING MainThread Setting emoncmsorg apikey: obscured
2018-12-07 19:17:14,746 INFO MainThread Setting emoncmsorg sendstatus: 1
2018-12-07 19:27:22,635 INFO MainThread Exiting hub...
2018-12-07 19:27:22,719 INFO MainThread Exit completed
2018-12-07 19:27:26,002 INFO MainThread EmonHub emonHub emon-pi variant v2.1.1
2018-12-07 19:27:26,003 INFO MainThread Opening hub...
2018-12-07 19:27:26,004 INFO MainThread Creating EmonModbusTcpInterfacer 'ModbusTCP'
2018-12-07 19:27:26,006 ERROR MainThread Unable to create 'ModbusTCP' interfacer: global name 'pymodbus_found' is not defined
2018-12-07 19:27:26,007 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2018-12-07 19:27:28,012 WARNING MainThread Device communication error - check settings
2018-12-07 19:27:28,014 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2018-12-07 19:27:29,017 INFO MainThread Setting RFM2Pi group: 210 (210g)
2018-12-07 19:27:30,020 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2018-12-07 19:27:31,022 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2018-12-07 19:27:32,025 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2018-12-07 19:27:33,030 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2018-12-07 19:27:33,036 INFO MainThread Setting MQTT nodevar_format_enable: 1
2018-12-07 19:27:33,037 INFO MainThread Setting MQTT node_format_enable: 1
2018-12-07 19:27:33,038 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2018-12-07 19:27:33,040 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2018-12-07 19:27:33,043 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2018-12-07 19:27:33,044 INFO MainThread Setting emoncmsorg senddata: 1
2018-12-07 19:27:33,045 WARNING MainThread Setting emoncmsorg apikey: obscured
2018-12-07 19:27:33,046 INFO MainThread Setting emoncmsorg sendstatus: 1
I have found some messages related but changing some code is not solved
It can work fronius and emconcms?
