Module v4.50 hex versions
Hi
Can anyone tell me what the different versions of module v4.5 hex files are?
The only difference in the names is 2K4, 5K and 10K - are these thermistor values?
Cheers
David.
Just worked this out - it’s different baud rates for the serial comms.
came across your query i have built some 4.5 boards .I am at a loss on how to program
the attiny1624.Can you tell me what programs you are using to program the board.I have built 16 of the 4.4 and programes them ok.But not a lot on youtube for flashing hex to these chips any pointers would be great.
The repositories on Github are not well organised for the v4.5 board. The code can be found here:
This also has a link to the binary files you’ll need - the different variants of firmware for v4.5 relate to the baud rate for comms between the boards and the controller. I just used the basic controller which defaults to 2400 baud.
The instructions for flashing the v4.5 modules can be found here:
I think I used this programme design:
