Module v4.50 fuse values
Hi
I can see in the github repo that the fuses are defined as all zero for 1624 mcu. avrdude config doesn’t define efuse, lfuse and hfuse for this mcu, it’s just ‘fuses’, with sub bytes of fuse0 to fuse8.
Does anybody know the fuse values that should be used for this?
Avrdude reports 0x0,0x0,0x7e,0xff,0xff,0xf6,0xff,0x0,0x0 for the fuses memory.
Many thanks
David.
this is fuse setting i am using for programming 1624
C:\Users\mgx\AppData\Local\Arduino15\packages\megaTinyCore\tools\python3\3.7.2-post1/python3 -u C:\Users\mgx\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.8/tools/prog.py -t uart -u COM5 -b 230400 -d attiny1624 --fuses 0:0b00000000 2:0x02 6:0x04 7:0x00 8:0x00 -fmodule_fw_V450_5K_ATtiny1624_450_e0_h0_l0.hex -a write -v
