I’m currently coding up some major improvements (IMHO) to the modules’ communication.
Specifically,
variable-sized messages, so short messages travel faster (and most are short!)
send packets along as soon as the header has been received, instead of store-and-forward: faster and needs less RAM
no more floating point code in the modules
adjust the balancer PID parameters without re-flashing
There’s more (for instance, my controller is a Raspberry Pi 2040, running MicroPython, and the “real” master is the Victron GX controller), but that’s a different topic.
As I don’t have ESP32 controllers, I also re-enabled ESP8266 support, which at least seems to compile even if I haven’t tested it lately. :-/
Am certainly curious about your work, especially since you mentioned using RP2040 as a controller.
Is your RP2040 configuration designed simply and only to be an interface between the modules and the “real” controller (e.g. Victron GX) or do you also have plans to use just a RP2040 as controller by itself …maybe with some sort of display attached or possibly use one of the newer wireless RP2040?
It’s certainly possible to use it as a controller by itself. If nothing else you can write a hardware adaption layer for it and otherwise use the existing ESP controller code and the C API.
Or you could link a couple of the required Python modules into ROM along with MicroPython, to free up some RAM space, and then add a basic HTTP(S) server. Problem is, most of these aren’t exactly written with MicroPython in mind and also take up too much RAM
That being said, yes my configuration is a “simple” interface, though I’m working on converting it to a “not-so-simple” frontend. However my basic tenet is that a BMS is a safety critical system, thus the non-safety-critical parts of managing the battery should be segregated off, and the link between the two should be as simple as possible.
My own roadmap is
clean up the code
refactor the cell serial stuff back into the controller, now that I know it works reliably
design a board for it, with a 72-to-12V downconverter, and most likely with a TinyRP piggyback instead of discrete RP2040 components to make it more accessible
