Hello everyone, I apologize for my English because it is translated by Google, I’m new in the forum and I write because I recently mounted a card MK2PV Robin.
My problem is that with MACBOOK Arduino IDE does not see the port where the MK2 card is connected. I installed the “Silicon Labs” Drivers but the card is not seen. I use an Open Energy Monitor USB card.
I am attaching some pictures of the assembled board.
Thanks Andrea
Hi Bill, I was able to load the sketch with a friend’s Windows, now I’m trying to figure out how to do with Mac.
I did a lot of tests … including that of exchanging RX / TX but not signs of life.
From what I understand you should create a virtual port with another COM …
I already asked Robim but he also advised me to write here because the USB interface is marked “openenergymonitor”.
The programming facilityfor any Arduino-type hardware is known as the Integrated Development Environment (IDE). Within the Arduino IDE, various adjustments may be required before any new code can be successfully uploaded:
- The Tools->Board setting should be “Arduino/Genuino Uno”. - The Tools->Programmer setting should be “AVRISP Mk11” (for any programmers that I supply). -The Tools->Port setting should match whichever new port appears when the programmer is connected to the host computer.
NB. To see the results of any Serial.print() statements, the baud rate of the Serial Monitor must match the Serial.begin(<baud rate>) command in the sketchthat is running . To open the Serial Monitor window, click the “magnifying glass” icon on the main IDE screen. The baud rate can then be changed using the drop-down menu. My software always operates at 9600 baud.
Thanks Jon, I know the IDE well enough and the basic settings are correct, I also installed the “silabs” Driver as re-posted on the site you posted. The problem is that when I go to select the door … there is no door to select
The Atmel 328P processor on my Mk2 PV Router PCB is programmed in just the same way as the emonTx. I’ve added a link to this helpful thread from my website mk2pvrouter.co.uk
