I’ve just downloaded the latest emonSD image -
Git
URL https://github.com/emoncms/emoncms.git
Branch * stable
Describe 10.1.9-19-g1f3e991e
and flashed to a 32GB card using BalenaEtcher as suggested. I enabled SSH using the ‘ssh’ file in /boot , however, I don’t appear to be able to expand the image to the entire card as per the README?
Connect via SSH and run $ sudo emonSDexpand and then follow prompts.
However, the emonSDexpand script/code appears not to exist?
pi@emonpi:/ $ sudo emonSDexpand
sudo: emonSDexpand: command not found
pi@emonpi:/ $
Has anyone else come across this problem?
Andrew
