frro
(Francis)
20 March 2018 21:09
1
Hi, I was looking for the arduino sketch that “boelle” had in an attachment to a post on Fri, 05/09/2014 - 17:07.
https://openenergymonitor.org/forum-archive/node/5713.html
The post is archived, I believe this is the reason the attachment is not available?
It would be really great if you could find it. I’m in the process of trying to get data out of the Kamstrup 601 energy meter.
Regards
Francis
Paul
(Paul Reed)
20 March 2018 21:17
2
Let’s ask @boelle if he still has it.
Paul
boelle
(Bo Herrmannsen)
20 March 2018 21:26
3
sadly he does not :-/
distrct heating company offered remote readout down to hour basis if i wanted to pay the extra
so i opted for dalily readout that i can get at their website
boelle
(Bo Herrmannsen)
20 March 2018 21:29
4
i was also contacted on facebook and explained in danish where i got my inspiration from
https://wiki.hal9k.dk/projects/kamstrup
site is in danish but code is there and also google translate goes a long way
frro
(Francis)
20 March 2018 21:38
5
Maybe you have access to the archive/attachments?
boelle
(Bo Herrmannsen)
20 March 2018 22:01
6
boelle
(Bo Herrmannsen)
20 March 2018 22:14
7
i might be wrong but i think the code to get data out of the heat meter is:
Download it and save as a text file (.ino) and all is OK.
It is only when viewed in a browser that you have a problem - there are no HTML <br> symbols in it.
boelle
(Bo Herrmannsen)
20 March 2018 22:44
9
oki… new pastebin: -------------------------------------------------------------------------------- - Pastebin.com
NOTE: serial pins for the IR head for the heat meter is not set at this stage
Hai francis, have you succeeded? I want the same and tried the script below:
I get back of my serial arduino serial monitor: crc error or data timeout.
I use the right pins 9 and 10.What can I try else?
BezbLemZ.zip (2.3 KB)
Edit - attached script to post. BT - Moderator
You’re replying to a post that is almost two years old. The party to whom you addressed your
question hasn’t been on the forum since March of 2018. You may or may not get an answer.
Please attach your scripts directly to your post. If the third party site you linked to becomes
unavailable, you post loses its value. I’ve done that for the script mentioned in your post above.
