Has anybody noticed that the Mitsubishi ecodan Ashp flow rate temperature values have been greyed out on the MELCloud app. (In the last month) ?
I hadn’t looked at it before, but the support page doesn’t help.
The Ecodan Homeowner Helpline number is 0161 866 6064
Thanks I will give them a call.
No. That’s what happens if you click the key. If you click/tap “Flow Temperature”, it will get its colour back and reappear on the graph. Similarly “Return Temperature”. And you might want to do “Flow Temperature Boiler” (to switch it off) unless you have a boiler.
Brilliant!!! Thank you very much. I now have all my flow data back. I must have disabled it by mistake. ![]()
