Lower charging current at night
Hello,
I have an OpenEVSE capable of 16 A - one phase.
During day or when manually overriden, 16 A is fine.
During night, when there is enough time to charge, I would like to limit the max current to 6A to take better care ot the battery (as far as I can understand, lower charge current sould be better for the battery expected life).
  1. How can I achieve this ?
  2. Is this a good idea ?
    I read in this post that lower current means lower charge effiency. Is it always the case ?
Thanks.
I doubt 3.6kw is considered as high current for such batteries. You will have more energy loss lowering the current also ( voltage drops through cables and the embedded ev inverter is less efficient at low current)
This won’t change nothing to your battery life
AC charging isn’t fast enough to wear the battery, leaving the battery at a high state of charge for prolonged periods would be more significant problem for normal NMC lithium.
In my testing charge rates less than 15A are measurably less efficient. I think due to the fixed overheads running the car computer fans etc. These efficiencies listed below are based on mathematical expectations/ measured charge rate.
PS: edited to add more results: 6A is significantly less efficient than 10A or 15A!
Polestar 2:
6A or 1.44kw: 1.9%/h (real 1.54%/h) 80.2% efficient.
10A or 2.4kw: 3.2%/h (real 2.7%/h) 84% efficient
15A or 3.6kw: 4.8%/h (real 4.3%/h) 89.5% efficient
20A or 4.8kw: 6.4%/h (real 5.7%/h) 89% efficient
32A or 7.6kw: 10%/h (probably 9%/h)
3 phase 11kw: 14.6%/h (real 13.3%/h) 91% efficient
(Note there’s some rounding errors but 15A and higher is probably peak efficiency.)
