Do I have to delete all data before 15/2/20 9:10:00 am to get back on track or can I get back all my history
Also can you use a USB UPS with the emonPI and if so can you recommend one.
I am not too confident on doing this but I have ordered a 16gb card and reader & downloaded BalenEtcher so I will start off by getting a new card set up I am running emonSD-300ct18 at the moment should I download that or emonSD-17Oct19 (Stable).
I dont have any backup from before the power failure so if the disk errors can not be fixed will I have to start from scratch and set up the local system again
It is all working correctly at the moment only the history is not there. I even set up all new feeds, instead of _kwh I added _kwh2 & redirected the apps to that feed but still no history although all the graphs show the data correctly. The only change I can detect is that the _kwh feeds start from zero again after the power cut
I still have all my data running correctly on emoncms so it is not really a big deal, but if I have to reinstall everything again as long as I alter the api key to ********6f42e in the config file would it still post data to emoncms with no problems.
I have ordered a UPS to hopefully stop this happening in the future, as I had another power cut this morning at 4am all the feeds seemed ok this time but the consumption had gone right up until I rebooted and then it went back to normal.
