However @sjthespian’s system seems to have several more drives or mount points listed and whilst the count doesn’t effect the formatting, the fact that one of those mount points has a rather long name and path, it is forcing the second table column to be significantly wider.
Since we do not have any control over what users may call their files/folders nor what depth the paths may go, I think there needs to be a limit set to only show the first ~30 chars and ellipsis when the path/name string is any longer perhaps.
Just to be clear, I wasn’t asking or expecting you to do it, I was just expressing an opinion. I might have thought about opening a issue so it doesn’t disappear off into the depths of the forum, but I’ll hold off if you are taking a look.
If the VM has no access to external devices then no, that won’t work.
Can you retrospactively add another partition? (and remove it later?) alternatively, if this is a test VM, I believe you can re-mount mountpoints multiple times to different mountpoints, but I do not know how that might play out in a VM. Do you have a sepearte data partition you could also mount as /media/$longname?
Otherwise, how bigga edit is it? could @sjthespian try it out if you ask him nicely?
[edit] having said that . . . Where is your ramlog in your server info? Does tmpfs show as a valid mountpoint normally on an emonpi? I know DeitPi is different to the emonPi’s logfile location.
