Hello All,
I have a smart meter telegram receiver, that reads the import and export for the electricity every 10 seconds. It has 4 accumulating values, that register the kilowatt hours since it was installed, in an always increasing value. The kWh value has 3 decimals, this I convert to Wh, by multiplying the value with 1000.
The logger has an xml output, that is read by a shell script on the emonPi, the contents are as follows;
3729.814
2801.061
1300.004
3323.952
The first two values show the input, for day and night tariff, the second two the energy export for day and night tariff since the meter got installed.
I log all 4 values to a feed in emoncms, and the sum of both input and the sum of both outputs to different feeds.
So far so good.
But now i want to create a feedvalue in kwh per day, and a feed where I can create a bargraph for, so I can see the use per day, month, year.
Can someone enlighten me on the best practice for creating those feeds?
